Regression: Geometry Nodes > Spline Parameter > Factor Output
Graphics card: NVIDIA GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash: rBe05e1e369187
Worked: 3.1.2
Caused by rBf4f89a76a8f4: Curves: Port parameter node to the new data-block
Factor output produces unexpected results in Spline Domain.
Open attached .blend file
Mark David Bas (MaveBas) renamed this task from Geometry Nodes > Spline Parameter > Factor Attribute to Geometry Nodes > Spline Parameter > Factor Output.Aug 7 2022, 7:41 AM
Mark David Bas (MaveBas) updated the task description. (Show Details)
Iliya Katueshenock (Moder) changed the task status from Needs Triage to Confirmed.EditedAug 8 2022, 2:39 AM
If change the resolution, the error changes. Looks like +-1 index error
Although I'm not sure about it
+Hmm, no, there is still a lot of strange and unknown in the code, but it's not about indexing
++ The error does not decrease with increasing accuracy! It is minimum at minimum precision and is fixed at 100~
Philipp Oeser (lichtwerk) renamed this task from Geometry Nodes > Spline Parameter > Factor Output to Regression: Geometry Nodes > Spline Parameter > Factor Output.Aug 16 2022, 10:25 AM
Philipp Oeser (lichtwerk) triaged this task as High priority.
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
