SHADOW bug on LAshes
Operating system: Windows 10
Graphics card: RTX 3070
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Still have the shadow bug under the eyelashes, when rendering even on 4k. please fix this was a problem sionce 3.1 and still have on 3.3 beta
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.EditedAug 10 2022, 4:54 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Can you please provide us with more information? For example, can you provide us a .blend file with the issue, or the exact steps required to reproduce the bug?
