project from view Issue
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash: rBa2d59b2dac9e
  • select the object
  • change the mode to edit,
  • select the object
  • then hit the keyword "U".
  • select project from view
I'm UNABLE to view the texture both in layout mode & UV
I'm unable to view texture in project from view
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Aug 23 2022, 3:08 PM
This report does not contain all the requested information, which is required for us to investigate the issue.
Please carefully follow the instructions. Be sure to provide a blend file with exact steps to reproduce the problem (and also explain the issue you're experiencing).
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
I have attached the following files. PFA{F13418456}
  1. When I select the object & change the mode to edit, then I select the object then hit the keyword "U".
  2. after pressing the U word & selecting project from view I'm UNABLE to view the texture both in layout mode & UV
{F13418454}Editing mode.
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Sep 17 2022, 5:27 AM
I edited the description to try to better understand the problem, but even so, even with the file provided, I didn't understand the problem.
It looks like this isn't really about a bug, but a support request.
For help using Blender, please try one of the community websites: https://www.blender.org/community/
If you think you found a bug, please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
