Crash Blender when add motion blur or motion vector to render point cloud
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.3.0 Beta, branch: master, commit date: 2022-08-18 18:04, hash: rB6a4f4810f38b
Import particles by alembic file ( becourse Blender can`t import vdb generated by mantaflow)
apply GN modifier to visuailize particles and can`t render with motion Blur or render with motion vectors chek On.
allways crash.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Aug 27 2022, 7:02 AM
Thanks for the report. Please share the alembic file you're using
file is so huge. I can upload it on senspace if you want
Hi, please simplify file as much as possible. we require the bug reporter to narrow down the problem.
Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly.
Thanks for these files. What is the exact way to redo the crash btw?
What I've done is: import alembic in default scene -> Add GN tree -> Enable motion blur -> Switch to viewport render
Hi, please provide the requested info
I can't reproduce a crash. The BUG MB.blend file renders fine for me. I also tried importing test splash render.abc and rendering it in Cycles/EEVEE with motion blur. But no crash for me.
We ened more specific instructions on how to trigger the crash.
Thanks @Martijn Versteegh (Baardaap). I'll close this task for now due to inactivity.
