Shortcut keys become unusable in the middle of using blender
Operating system: macOS-10.14.6-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 555 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.21
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: rBcc66d1020c3b
とにかくキーボードの機能が、blenderを起動して、やっている途中で反応しなくなります。最近よくあります。
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Aug 31 2022, 7:39 AM
Hi, thanks for the report. Information you've provided is not sufficient for us to investigate this issue further.
Does this happen when you switch between apps and come back to blender?
Do we need particular setup to reproduce this issue?
Please check again with factory settings: FileDefaultsLoad Factory Settings
Pratik Borhade (PratikPB2123) renamed this task from ショートカットキーなどがblenderを起動して、している途中で使えなくなる。 to Shortcut keys become unusable in the middle of using blender.Aug 31 2022, 7:40 AM
Thomas Dinges (dingto) closed this task as Archived.Sep 14 2022, 2:28 PM
