Regression: Backface of mesh appears as completely back when using a normal map texture with ambient occlusion enabled in Eevee
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.94
Broken: version: 3.3.0 Release Candidate, branch: master, commit date: 2022-09-02 20:48, hash: rB831ed297d0a0
Worked: 3.3.0 Beta, branch: master, commit date: 2022-08-28 21:53, hash: 7b56c7488106
First bad commit: rB07cf3ce92fa2: Fix T100377: EEVEE: Regression 3.2 normalmap node broken
When using a normal map image, the backface of the mesh appears as black. This was not happening with the previous 3.3 build I was using.
If I disable Ambient Occlusion, this behavior does not happen.
the backface is black in the latest build
the backface looks good in the previous build
  1. Attach a normal map to a plane
  2. Enable Ambient Occlusion
  3. The backface of the plane will appear as completely black, while previously it didn't using the same normal map
Here is a .blend displaying the behavior:
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Sep 3 2022, 11:46 AM
Thanks for the report. I can confirm. Checking when it was changed
Philipp Oeser (lichtwerk) renamed this task from Backface of mesh appears as completely back when using a normal map texture with ambient occlusion enabled in Eevee to Regression: Backface of mesh appears as completely back when using a normal map texture with ambient occlusion enabled in Eevee.Sep 3 2022, 12:29 PM
