Shadow Catcher with textured lights - Incorrect shadow?
Operating system: Mac OS and Win10
Graphics card: Apple Silicon, Nvidia Quadro RTX 6000
Broken: Tested in 2.83 till 3.4
Worked: Never?
The shadow catcher combined with textured lights seems to perform in an unrealistic way. Is this a bug or am I missing something? Thanks for your work and help!
Just turn on and off the shadow catcher to see the difference in shadow. Can this be fixed somehow?
Oleg Kauz (OlegKauz) renamed this task from Shadow Catcher with textured lights - Incorrect shadow? to Shadow Catcher with textured lights - Incorrect shadow?.Sep 8 2022, 11:52 AM
Oleg Kauz (OlegKauz) updated the task description. (Show Details)
Alaska (Alaska) closed this task as Archived.Sep 8 2022, 12:37 PM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Everything is working as expected.
The shadow catcher is capturing shadows (the lack of light). And the pattern you see corresponds with the cube blocking light from the textured spot light.
Thanks! I get your point from a technical perspective, but the cube is solid and should cast a solid shadow (even though it catches textured lights). Is there a fix for this?
