Flickering in Viewport Shading/Render
Operating system: macOS-12.6-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: rB0759f671ce1f
If I move the mouse/arrow during a render preview in the Editor Types, for example Outline and/or Properties the viewport flickers during the render. It stop when the render finish. It happens in scene with some models
Create a scene with a plane and other objects
Scatter them on the plane
Assign some textures
try to preview
Thanks,
PJ
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Sep 16 2022, 4:07 PM
Can you attach a recording of such flickering? What render engine are you using? Cycles or EEVEE?
If Cyckes, are you using the Metal device? If so, does it happen with CPU rendering as well?
