Regression: Smooth Brush leaves artifacts when face sets are hidden.
Closed, ResolvedPublicBUG
Broken: 3.4
Worked: 3.3Lts
Caused by rBb5f7af31d6d4: When these features aren't used, there is no sense in storing the
Short Description
If you use the smooth brush while face sets are hidden. The geometry acquires significant artifacts.
The same operation did not cause these artifacts in 3.3
To reproduce
  • Open the attached blend file. It is a sphere with some hidden face sets.
  • In sculpt mode, use the smooth brush on the large white face set.
  • You should observe artifacts.
Guess this should be treated as a separate report?
  • Unhide all the face sets and the smoothing brush should then behave normally.
  • Hide all the face sets except for one of the small ones.
  • Try to smooth that face set and smoothing will have no effect at all.
I'm also experiencing this. Happened between September 13, 10:31:59 4130f1e674f8 and September 13, 17:20:19 109cc14dba98
Just tested this on slightly older build of 3.4 on an M1 mac and the bug is not present. System info attached
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Sep 27 2022, 4:43 AM
Pratik Borhade (PratikPB2123) triaged this task as High priority.
Pratik Borhade (PratikPB2123) renamed this task from 3.4 Sculpting Smoothing Brush leaving artifacts when face sets are hidden. to Regression: Smooth Brush leaves artifacts when face sets are hidden..Sep 27 2022, 4:46 AM
Pratik Borhade (PratikPB2123) updated the task description. (Show Details)
Hans Goudey (HooglyBoogly) changed the subtype of this task from "Report" to "Bug".
Thanks for the report and the bisecting!
