In blender-3.4.0-alpha+master.e2df1958449a Wavelength node doesn't work after input values of 700 in Cycles
Related Objects
Related Objects
Comment Actions
Visible light only exists between 380nm and 780nm which is the range of that node (all prior versions I tested show the same once you get close to 780nm). Did you maybe mean to use the Blackbody node instead of Wavelength?
Comment Actions
Thank you. This is it. I used it before with more nodes with Mix Color and naturally notice it doesn't produce light after 780nm.
This should be closed.
