Certificate Expired / Failed Blender Installation vis scoop.sh : https://download.blender.org/release/Blender3.3/blender-3.3.0-windows-x64.zip
Operating system: Windows 10
Graphics card: n/a
Broken: Installing Blender 3.3 using scoop.sh installer results in failed validation procedure
Worked: This worked as of release date for 3.3 on another machine using the same installation method
Installing via scoop.sh, using powershell to run "scoop install blender" results in the error message:
Installing 'blender' (3.3.0) [64bit] from extras bucket
The remote certificate is invalid according to the validation procedure.
URL https://download.blender.org/release/Blender3.3/blender-3.3.0-windows-x64.zip is not valid
Checking the URL with a browser results in an Error: NET::ERR_CERT_AUTHORITY_INVALID
It appears the Certificate is invalid or expired
Run Powershell
Run the following commands as per scoop.sh
Set-ExecutionPolicy RemoteSigned -Scope CurrentUser # Optional: Needed to run a remote script the first time
irm get.scoop.sh | iex
install git
scoop bucket add extra
Robert Shea (rshea) renamed this task from Certificate Expired / https://download.blender.org/release/Blender3.3/blender-3.3.0-windows-x64.zip to Certificate Expired / Failed Blender Installation vis scoop.sh : https://download.blender.org/release/Blender3.3/blender-3.3.0-windows-x64.zip.Sep 29 2022, 10:26 AM
Robert Shea (rshea) created this task.
It seems to be working fine for me.
* Server certificate:
*  subject: CN=download.blender.org
*  start date: Aug 27 21:01:45 2022 GMT
*  expire date: Nov 25 21:01:44 2022 GMT
*  subjectAltName: host "download.blender.org" matched cert's "download.blender.org"
*  issuer: C=US; O=Let's Encrypt; CN=R3
*  SSL certificate verify ok.
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Sep 29 2022, 2:20 PM
Can you double check that your computer's date and time is correct? Maybe sync the time from Windows settings just to make sure.
Thank you Omar, I checked this first. But the data and time are correct.
I tried on some different machines, and they have no error. It looks like it could be an issue with the Windows Root Certificate updater.
Thanks for the help.
