Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 517.40
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
Hair curves are not showing properly the segments in every strand
-Grab a model and add empty hair
-Add with density or either add brush some hair strands with default settings except the length is decreased (which is working)
-Add more hair but with more segments for example 24, 50, and 100 were tested with same length as before (2 cm in my case)
-Comb the hair to see if the hair looks smooth on the subdivided strands (Hair fails to look smooth after increasing the default 8 segments, for example 24,50 or 100 of value i tried but doesn't change anything after adding more hair instead stays at 8 points when i comb it)
-Try converting the hair curves to hair particles to see if any change happens
-then go to particle edit mode and i notice that the segments are indeed there but look like this: seems that again the default segment count seems to remain in the strand but i can see the dots of the segments that i supposedly added before there but without any strand, but they are still deforming as i comb the hair from there...
