Using Subsurf Modifier Freezed Blender
Operating system: Windows-10-10.0.22621-SP0 64 Bits
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 27.20.100.8854
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
Worked: Using old version produces same error
[Adding Sub-division surface Modifier freezes blender]
  1. Open Blender
  2. Go to modifier tab
  3. Select subdivision surface modifier
  4. Blender is freezing
This comment was removed by Ajay Prasad (risingswan).
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Oct 16 2022, 8:15 PM
Please update GPU drivers. If that doesn't help, check if disabling Viewport > Subdivision > GPU subdivision in Preferences resolves the crash.
Updating GPU drivers doesn't worked however disabling GPU subdivision worked. Thanks.
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Triage.Oct 24 2022, 9:14 PM
Thanks for update. I see @Aaron Carlisle (Blendify) have access to same GPU in hardware list, can you check?
CC @Kévin Dietrich (kevindietrich)
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Oct 25 2022, 4:06 AM
@Ajay Prasad (risingswan) hi, please upload system info file: HelpSave System Info
Did you update IGPU drivers from intel website or device manager?
No crash here on Linux.
@Pratik Borhade (PratikPB2123) attached system info
drivers were updated from intel website
Hi Ajay, system-info captured 27.20.100.8854 as your driver version so I doubt they are recent.
As far as I can tell, recent version is 31.0.101.3790 / 31.0.101.2114: https://www.intel.in/content/www/in/en/download/19344/intel-graphics-windows-dch-drivers.html
hi, did you check with them?
Thomas Dinges (dingto) closed this task as Archived.Dec 15 2022, 4:40 PM
