it's impossible for me to use a second empty hair
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.40
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
j'aimerais rajouter un empty hair et m'en servire. le problème c'est que quand j'essaye de me servire peut importe l'outil dans le sculpte mode Blender menasse ce crashé. et au final il ce passe rien.
Invalid UV map: UV Island must not overlap (alors que les UV ont était fait correctement) Blender menace de craché comme l'action prenez beaucoup de ram et pourtant aucun soucis de ram.
I would like to add an empty hair and use it. the problem is that when i try to use any tool in blender sculpt mode it threatens to crash. and in the end nothing happens.
Invalid UV map: UV Island must not overlap (even though the UVs were done correctly) Blender threatens to spit as the action takes a lot of ram and yet no ram worries.
I select my pegasus.
CTRL+A curve Empty Hair
switch to sculte mode mode selected a tool (the error works with all the tools)
add particles to the pegasus.
https://drive.google.com/file/d/1R_JOTWsvaLmkJ0x2xmTN-aj0f_XzUALX/view
Pratik Borhade (PratikPB2123) renamed this task from il mes impossible d'utilisé un deuxième empty hair to it's impossible for me to use a second empty hair.Oct 21 2022, 5:17 AM
Pratik Borhade (PratikPB2123) updated the task description. (Show Details)
Pratik Borhade (PratikPB2123) closed this task as Archived.EditedOct 21 2022, 5:43 AM
Thanks for the report. As message says, split overlapped UVs to use curve sculpt brushes (use SelectSelect Overlap for detecting overlapped UV)
This is not a bug as far as I can tell. For help using Blender, please try one of the community websites: https://www.blender.org/community/
If you think you found a bug, please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
I guess you've used Smart UV Project for the unwrapping
Il y déjà tout dans le. Ticket. Vérifier mes UV si vous voulez mais je peut vous assurer qu'ils ont déjà était séparer.
