GPU compute grayed out, even with correct graphics card and updated drivers
Operating system:Ubuntu 20.04.1
Graphics card: AMD Radeon 6700 XT
3.31
When I click "GPU Compute", it's grayed out.
I have everything it says I need it Preferences > System, but it still says i don't have a compatible graphics card. Tried this on Windows, still doesn't work.
Open Blender
Go to the Render Properties tab
Select Cycles as rendering engine
Select GPU Compute in Devices
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Oct 23 2022, 11:43 AM
Thanks for the report. Did you get any message printed in the console?
Does this happen in default cube file? Maybe render kernels are loading at the time of freeze.
No. It didn't freeze in the first place, anyways.
I did it in the default cube file, too. It doesn't even work on any files at all.
Thanks. Please launch blender with --debug-cycles/--debug-gpu argument. See if that prints any relevant error and paste it here.
Please also upload system info: HelpSave System Info
I use the Steam version, so I can't do that.
Hi, from the information I got, it's not possible to run blender in steam with command line arguments
In windows, you could do that. Locate exact path of blender executable. There You'll find batch files blender_debug_gpu_glitchworkaround / blender_debug_gpu
Double click to run these batch files and reproduce the issue in that. After closing blender, log files will generate. Upload them here.
Thomas Dinges (dingto) closed this task as Archived.Dec 15 2022, 4:38 PM
