when S is pressed it won't scale my low poly trees for my game that i am working on.
Related Objects
- Duplicates Merged Here
- T102315: scale not working
Can you please provide us with some more information.
For example, what Blender version are you using? What steps are required to reproduce the issue? Does it effect all .blend files or just one? If it only impacts one, can you share that .blend file with us so we can see what might be causing it?
Hi, thanks for the report. Maybe you've changed the keymap for scale option. Try factory reset if this is the case: File → Defaults → Load Factory settings
Another reason for S to not work would be Affect only: origins/location is enabled in options panel.
These are just guesses. A .blend file will help in finding the cause.
Report is incomplete so I'm closing it for now.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file > with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
