Blender Crashing after adding Custom font strip to Video Sequencer
Graphics card: AMD Radeon (TM) Pro WX 7100 Graphics ATI Technologies Inc. 4.5.14800 Core Profile Context FireGL 22.Q2 30.0.21020.2
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash: rBb292cfe5a936
Worked: (newest version of Blender that worked as expected) 3.2.2
[Crashes upon video sequencer timeline hitting a custom font text strip after saving the .blend file, closing, and re-opening ]
[Start blender in video editing mode. Add image sequence to sequencer. Add text strip with custom font on another channel overlapping the image sequence. Save .blend file and close. Re-open saved file and press play in the video sequencer or drag the timeline in the video sequencer to the text strip with the custom font. Blender crashes at the custom font text strip. ]
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Nov 15 2022, 5:21 PM
Hi, thanks for the report. I'm unable to reproduce the crash in 3.3.1 with below setup. Can you confirm whether it is correct?
Could you also share crash logs?: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#windows
Wayne Franklin (aapsoftool) claimed this task.
I apologize. It seems to be something wrong with several blend files I have created in an older version. Then opened in 3.3.1. The latest file I created with 3.3.1 is not having any problems including the one you created. Sorry for wasting your time. Thanks for the quick response.
Thanks for the update. Maybe it'd still be considered as a valid bug if you've a exact way to generate a file in previous versions.
