I'm Having Problems With Blender, Windows And Linux Shortcuts!
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
My Linux BLender shortcuts don't work like they do on Windows
For example, in Windows I can Select All the Corners with (Alt) + (Left Click), But when I want to do this in Linux, the Window goes into Motion Mode... Will I Have Such Problems on Every Short Road? What is the Solution?
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Dec 19 2022, 10:04 PM
What is the "Motion Mode"? is this some feature of linux window manager?
Yes, I Solved the Problem from the Settings, But Now the Inside (I) Key is Not Working...
Faruk (fmy) added a comment.EditedDec 20 2022, 8:44 AM
The problem was related to the Keyboard layout of my language
Blender Can't Detect the Small(i) on my Slice as the Big(I) in english :(
As far as I know, blender assumes english keyboard layout is used. This is by design.
So i key on turkish layout, should be recognized as S key. N key in turkish layout should correspond to I key
Faruk (fmy) added a comment.EditedDec 21 2022, 7:45 AM
I Tried What You Said Unfortunately Not So, Blender Cannot Detect Small(ı) in Turkish as Big(I) in English(At least on Linux)
Unfortunately I am not sure if I can reproduce this even ok Linux system. Will try, but please click on Help > Save System Info and upload provided file, so I can see OS details.
Richard Antalik (ISS) closed this task as Archived.Jan 8 2023, 7:09 PM
