Lots of Color wheel freezes in Blende 3.4 on Mac Studio. can you help?
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Translated Report (Full Report Below)
Process: Blender [6314]
Path: /Applications/Blender.app/Contents/MacOS/Blender
Identifier: org.blenderfoundation.blender
Version: 3.2.2 (3.2.2 2022-08-03)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-12-24 01:54:47.3306 -0800
OS Version: macOS 13.1 (22C65)
Report Version: 12
Anonymous UUID: 0258BF94-8D3A-D177-BD53-7A947BD9CA6C
Sleep/Wake UUID: E589DB4E-1524-4D43-B0F6-81EDFBC828F9
Time Awake Since Boot: 47000 seconds
Time Since Wake: 38612 seconds
System Integrity Protection: enabled
Crashed Thread: 2
Exception Type: EXC_CRASH (SIGSEGV)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: Blender [6314]
Thread 0:: Dispatch queue: com.apple.main-thread
0 <translation info unavailable> 0x12b629398 ???
1 Blender 0x1003efbd1 BKE_blendfile_read_setup_ex + 1713
2 libsystem_platform.dylib 0x7ff81b733c33 _sigtramp + 51
3 Blender 0x1003efbd1 BKE_blendfile_read_setup_ex + 1713
4 Blender 0x1003ef1fa BKE_memfile_undo_decode + 250
5 Blender 0x1016f62e4 memfile_undosys_step_decode + 148
6 Blender 0x10078a71f undosys_step_decode + 271
7 Blender 0x10078a547 BKE_undosys_step_load_data_ex + 695
8 Blender 0x1016f4bc0 ed_undo_step_direction + 208
9 Blender 0x1016f531b ed_undo_exec + 43
10 Blender 0x100aed293 wm_operator_invoke + 531
11 Blender 0x100af1faa wm_handler_operator_call + 714
12 Blender 0x100af1265 wm_handlers_do_intern + 2149
13 Blender 0x100af03f0 wm_handlers_do + 48
14 Blender 0x100aefe26 wm_event_do_handlers + 4150
15 Blender 0x100ae6620 WM_main + 32
16 Blender 0x1003a6d8e main + 878
17 dyld 0x21681e310 start + 2432
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime 0x7ff7ffddd614 0x7ff7ffdd9000 + 17940
1 runtime 0x7ff7ffde9530 0x7ff7ffdd9000 + 66864
2 runtime 0x7ff7ffdeaf30 0x7ff7ffdd9000 + 73520
Thread 2 Crashed:
0 ??? 0x7ff8aaa3e9a8 ???
1 libsystem_kernel.dylib 0x7ff81b6ca53e semaphore_wait_trap + 10
2 libdispatch.dylib 0x7ff81b589efb _dispatch_sema4_wait + 16
3 libdispatch.dylib 0x7ff81b58a3d7 _dispatch_semaphore_wait_slow + 98
4 Blender 0x10b7d86f2 IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run() + 50
5 Blender 0x10b7d71ee void* std::1::thread_proxy<std::1::tuple<std::1::unique_ptr<std::1::thread_struct, std::1::default_delete<std::1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*) + 62
6 libsystem_pthread.dylib 0x7ff81b709259 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff81b704c7b thread_start + 15
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
0 runtime 0x7ff7ffdfb87c 0x7ff7ffdd9000 + 141436
Thread 23:
Thread 24:: caulk.messenger.shared:17
2 caulk 0x7ff8253b78f8 caulk::mach::semaphore::wait_or_error() + 16
3 caulk 0x7ff82539d664 caulk::concurrent::details::worker_thread::run() + 36
4 caulk 0x7ff82539d328 void* caulk::thread_proxy<std::1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
5 libsystem_pthread.dylib 0x7ff81b709259 _pthread_start + 125
6 libsystem_pthread.dylib 0x7ff81b704c7b thread_start + 15
Thread 25:
Thread 26:
1 libsystem_kernel.dylib 0x7ff81b6ca5c2 mach_msg2_trap + 10
2 libsystem_kernel.dylib 0x7ff81b6d8604 mach_msg2_internal + 82
3 libsystem_kernel.dylib 0x7ff81b6d1635 mach_msg_overwrite + 723
4 libsystem_kernel.dylib 0x7ff81b6ca8a8 mach_msg + 19
5 CoreFoundation 0x7ff81b7e401b CFRunLoopServiceMachPort + 145
6 CoreFoundation 0x7ff81b7e2a74
CFRunLoopRun + 1387
7 CoreFoundation 0x7ff81b7e1e8f CFRunLoopRunSpecific + 560
8 CoreFoundation 0x7ff81b8660f5 CFRunLoopRun + 40
9 3DconnexionClient 0x136485080 -[ConnexionClientAPI clientThreadEntry] + 220
10 Foundation 0x7ff81c57082c NSThreadstart__ + 1009
11 libsystem_pthread.dylib 0x7ff81b709259 _pthread_start + 125
12 libsystem_pthread.dylib 0x7ff81b704c7b thread_start + 15
Thread 27:: com.apple.audio.IOThread.client
5 CoreAudio 0x7ff81d964031 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
6 CoreAudio 0x7ff81d83725e HALC_ProxyIOContext::IOWorkLoop() + 4058
7 CoreAudio 0x7ff81d835c84 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 80
8 CoreAudio 0x7ff81d9c4748 HALB_IOThread::Entry(void*) + 72
9 libsystem_pthread.dylib 0x7ff81b709259 _pthread_start + 125
10 libsystem_pthread.dylib 0x7ff81b704c7b thread_start + 15
Thread 28:
Thread 29:
2 Blender 0x100adcb68 tbb::internal::rml::private_worker::run() + 104
3 Blender 0x100adcaf9 tbb::internal::rml::private_worker::thread_routine(void*) + 9
4 libsystem_pthread.dylib 0x7ff81b709259 _pthread_start + 125
5 libsystem_pthread.dylib 0x7ff81b704c7b thread_start + 15
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
Thread 46:
Thread 47:
Thread 48:: com.apple.NSEventThread
CFRunLoopRun + 1387
8 AppKit 0x7ff81e9c9299 _NSEventThread + 132
Thread 2 crashed with X86 Thread State (64-bit):
rax: 0x000000000000000e  rbx: 0x0000000000001503  rcx: 0x0000000200000003  rdx: 0x0000000200000003
rdi: 0x0000600000cdcff0  rsi: 0x0000000000000000  rbp: 0x0000160300000000  rsp: 0x00000d5a00000000
 r8: 0x0000000316cb1f50   r9: 0x0000160300000000  r10: 0x0000000000001503  r11: 0x0000000000000000
r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x0000600000cdd030  r15: 0xffffffffffffffff
rip: <unavailable>       rfl: 0x0000000000000283
tmp0: 0xffffffffffffffff tmp1: 0x00007ff8aaa3e978 tmp2: 0x00007ff81b6ccb82
Binary Images:
           0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
   0x10021d000 -        0x110424fff org.blenderfoundation.blender (3.2.2) <fc0d6f3e-2258-3015-9c00-db2bb3c063f3> /Applications/Blender.app/Contents/MacOS/Blender
0x7ff81b730000 -     0x7ff81b739ff7 libsystem_platform.dylib (*) <f314b62b-98f4-3a7c-8296-8739f8b6855a> /usr/lib/system/libsystem_platform.dylib
   0x216818000 -        0x2168affff dyld (*) <bb7a0970-8c62-3dce-a7a2-5cec9c501f11> /usr/lib/dyld
0x7ff7ffdd9000 -     0x7ff7ffe08fff runtime (*) <d592bc4a-4a21-348f-a406-e12f9cd2f27c> /usr/libexec/rosetta/runtime
0x7ff81b6c9000 -     0x7ff81b702ff7 libsystem_kernel.dylib (*) <7c3dcc95-9f42-3c7c-8796-476ff67b9cf7> /usr/lib/system/libsystem_kernel.dylib
0x7ff81b587000 -     0x7ff81b5cdff3 libdispatch.dylib (*) <6282e528-6a67-334b-accf-1f8fd89369bd> /usr/lib/system/libdispatch.dylib
0x7ff81b703000 -     0x7ff81b70eff7 libsystem_pthread.dylib (*) <5920e36f-53ec-33f0-b675-8ae48b58418c> /usr/lib/system/libsystem_pthread.dylib
0x7ff82539b000 -     0x7ff8253c0fff com.apple.audio.caulk (1.0) <66bba3ca-bce1-32f8-8269-99fac92469fc> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7ff81b765000 -     0x7ff81bbfcfff com.apple.CoreFoundation (6.9) <f3846a86-644b-3bcd-acce-fc7b751105c1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
   0x13647c000 -        0x136487fff com.3dconnexion.driver.client (1.2.4) <01c2ba10-7831-3ab7-983f-4bb9ace2b54f> /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
0x7ff81c518000 -     0x7ff81cf29ff6 com.apple.Foundation (6.9) <ab5f8db8-b03b-33b6-98f7-ffaec27a8eab> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7ff81d654000 -     0x7ff81dd71ffd com.apple.audio.CoreAudio (5.0) <97a3cd09-7112-376c-9613-7f38d4cf8c41> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7ff81e82b000 -     0x7ff81f832fff com.apple.AppKit (6.9) <00f4aa78-a19f-3a8e-9650-9f90b7beefd6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
Calls made by other processes targeting this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by this process:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
Calls made by all processes on this machine:
  task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=881.8M resident=0K(0%) swapped_out_or_unallocated=881.8M(100%)
Writable regions: Total=3.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=3.1G(100%)
VIRTUAL   REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 5376K 12
CG image 60K 5
ColorSync 228K 26
CoreAnimation 48K 7
CoreGraphics 20K 4
CoreUI image data 616K 5
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 644.4M 119
MALLOC guard page 192K 8
MALLOC_MEDIUM (reserved) 1.1G 11 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
OpenGL GLSL 256K 3
Rosetta Arena 4096K 2
Rosetta Generic 1296K 321
Rosetta IndirectBranch 1024K 1
Rosetta JIT 128.0M 1
Rosetta Return Stack 920K 92
Rosetta Thread Context 920K 92
STACK GUARD 16K 4
Stack 91.4M 48
Stack Guard 188K 44
VM_ALLOCATE 144.5M 182
VM_ALLOCATE (reserved) 544.0M 8 reserved VM address space (unallocated)
CTF 756 1
DATA 57.2M 495
DATA_CONST 16.4M 231
DATA_DIRTY 761K 123
FONT_DATA 2352 1
GLSLBUILTINS 5174K 1
LINKEDIT 249.0M 114
OBJC_RO 65.4M 1
OBJC_RW 1985K 2
TEXT 632.8M 500
dyld private memory 384K 3
mapped file 4.6G 1552
shared memory 1340K 17
unshared pmap 12.0M 9
TOTAL 8.7G 4051
TOTAL, minus reserved VM space 6.7G 4051
Full Report
{"app_name":"Blender","timestamp":"2022-12-24 01:55:09.00 -0800","app_version":"3.2.2","slice_uuid":"fc0d6f3e-2258-3015-9c00-db2bb3c063f3","build_version":"3.2.2 2022-08-03","platform":1,"bundleID":"org.blenderfoundation.blender","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.1 (22C65)","roots_installed":0,"name":"Blender","incident_id":"515A7E13-985E-47DB-B46B-7F7A9791D60D"}
"uptime" : 47000,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Mac13,2",
"coalitionID" : 3560,
"osVersion" : {
  "train" : "macOS 13.1",
  "build" : "22C65",
  "releaseType" : "User"
"captureTime" : "2022-12-24 01:54:47.3306 -0800",
"incident" : "515A7E13-985E-47DB-B46B-7F7A9791D60D",
"pid" : 6314,
"translated" : true,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2022-12-24 01:54:18.5126 -0800",
"procStartAbsTime" : 1129567907092,
"procExitAbsTime" : 1130259321583,
"procName" : "Blender",
"procPath" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
"bundleInfo" : {"CFBundleShortVersionString":"3.2.2","CFBundleVersion":"3.2.2 2022-08-03","CFBundleIdentifier":"org.blenderfoundation.blender"},
"storeInfo" : {"deviceIdentifierForVendor":"A95DD9A4-F9D5-5B56-BFC8-B06E7FF0DBD5","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "org.blenderfoundation.blender",
"crashReporterKey" : "0258BF94-8D3A-D177-BD53-7A947BD9CA6C",
"throttleTimeout" : 2147483647,
"wakeTime" : 38612,
"sleepWakeUUID" : "E589DB4E-1524-4D43-B0F6-81EDFBC828F9",
"sip" : "enabled",
"exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGSEGV"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"Blender","byPid":6314},
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 2,
"threads" : [{"id":457307,"queue":"com.apple.main-thread","frames":[{"imageOffset":5022847896,"region":"<translation info unavailable>","imageIndex":0},{"imageOffset":1911761,"symbol":"BKE_blendfile_read_setup_ex","symbolLocation":1713,"imageIndex":1},{"imageOffset":15411,"symbol":"_sigtramp","symbolLocation":51,"imageIndex":2},{"imageOffset":1911761,"symbol":"BKE_blendfile_read_setup_ex","symbolLocation":1713,"imageIndex":1},{"imageOffset":1909242,"symbol":"BKE_memfile_undo_decode","symbolLocation":250,"imageIndex":1},{"imageOffset":21861092,"symbol":"memfile_undosys_step_decode","symbolLocation":148,"imageIndex":1},{"imageOffset":5691167,"symbol":"undosys_step_decode","symbolLocation":271,"imageIndex":1},{"imageOffset":5690695,"symbol":"BKE_undosys_step_load_data_ex","symbolLocation":695,"imageIndex":1},{"imageOffset":21855168,"symbol":"ed_undo_step_direction","symbolLocation":208,"imageIndex":1},{"imageOffset":21857051,"symbol":"ed_undo_exec","symbolLocation":43,"imageIndex":1},{"imageOffset":9241235,"symbol":"wm_operator_invoke","symbolLocation":531,"imageIndex":1},{"imageOffset":9260970,"symbol":"wm_handler_operator_call","symbolLocation":714,"imageIndex":1},{"imageOffset":9257573,"symbol":"wm_handlers_do_intern","symbolLocation":2149,"imageIndex":1},{"imageOffset":9253872,"symbol":"wm_handlers_do","symbolLocation":48,"imageIndex":1},{"imageOffset":9252390,"symbol":"wm_event_do_handlers","symbolLocation":4150,"imageIndex":1},{"imageOffset":9213472,"symbol":"WM_main","symbolLocation":32,"imageIndex":1},{"imageOffset":1613198,"symbol":"main","symbolLocation":878,"imageIndex":1},{"imageOffset":25360,"symbol":"start","symbolLocation":2432,"imageIndex":3}]},{"id":457322,"name":"com.apple.rosetta.exceptionserver","frames":[{"imageOffset":17940,"imageIndex":4},{"imageOffset":66864,"imageIndex":4},{"imageOffset":73520,"imageIndex":4}]},{"triggered":true,"id":457325,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":24202140712960},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703588731778},"tmp1":{"value":140705991485816},"tmp0":{"value":18446744073709551615}},"rbx":{"value":5379},"r8":{"value":13267312464},"r15":{"value":18446744073709551615},"r10":{"value":5379},"rdx":{"value":8589934595},"rdi":{"value":105553129754608},"r9":{"value":24202140712960},"r13":{"value":0},"rflags":{"value":643},"rax":{"value":14},"rsp":{"value":14680198217728},"r11":{"value":0},"rcx":{"value":8589934595},"r14":{"value":105553129754672},"rsi":{"value":0}},"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457326,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457327,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457328,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457329,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457330,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457331,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457332,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457333,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457334,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457335,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457336,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457337,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457338,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457339,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457340,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457341,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457342,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457343,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457344,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":12027,"symbol":"_dispatch_sema4_wait","symbolLocation":16,"imageIndex":6},{"imageOffset":13271,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":98,"imageIndex":6},{"imageOffset":190559986,"symbol":"IlmThread_3_1::(anonymous namespace)::DefaultWorkerThread::run()","symbolLocation":50,"imageIndex":1},{"imageOffset":190554606,"symbol":"void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_3_1::Thread::*)(), IlmThread_3_1::Thread*> >(void*)","symbolLocation":62,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457345,"frames":[{"imageOffset":141436,"imageIndex":4}]},{"id":457346,"frames":[{"imageOffset":141436,"imageIndex":4}]},{"id":457347,"name":"caulk.messenger.shared:17","frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":116984,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":8},{"imageOffset":9828,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":8},{"imageOffset":9000,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":8},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457358,"frames":[{"imageOffset":141436,"imageIndex":4}]},{"id":457363,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5570,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":62980,"symbol":"mach_msg2_internal","symbolLocation":82,"imageIndex":5},{"imageOffset":34357,"symbol":"mach_msg_overwrite","symbolLocation":723,"imageIndex":5},{"imageOffset":6312,"symbol":"mach_msg","symbolLocation":19,"imageIndex":5},{"imageOffset":520219,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":145,"imageIndex":9},{"imageOffset":514676,"symbol":"__CFRunLoopRun","symbolLocation":1387,"imageIndex":9},{"imageOffset":511631,"symbol":"CFRunLoopRunSpecific","symbolLocation":560,"imageIndex":9},{"imageOffset":1052917,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":9},{"imageOffset":36992,"symbol":"-[ConnexionClientAPI clientThreadEntry]","symbolLocation":220,"imageIndex":10},{"imageOffset":362540,"symbol":"__NSThread__start__","symbolLocation":1009,"imageIndex":11},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457365,"name":"com.apple.audio.IOThread.client","frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5570,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":62980,"symbol":"mach_msg2_internal","symbolLocation":82,"imageIndex":5},{"imageOffset":34357,"symbol":"mach_msg_overwrite","symbolLocation":723,"imageIndex":5},{"imageOffset":6312,"symbol":"mach_msg","symbolLocation":19,"imageIndex":5},{"imageOffset":3211313,"symbol":"HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)","symbolLocation":111,"imageIndex":12},{"imageOffset":1978974,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":4058,"imageIndex":12},{"imageOffset":1973380,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":80,"imageIndex":12},{"imageOffset":3606344,"symbol":"HALB_IOThread::Entry(void*)","symbolLocation":72,"imageIndex":12},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457377,"frames":[{"imageOffset":141436,"imageIndex":4}]},{"id":457421,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457422,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457423,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457424,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457425,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457426,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457427,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457428,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457429,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457430,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457431,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457432,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457433,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457434,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457435,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457436,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457437,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457438,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457439,"frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5438,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":9173864,"symbol":"tbb::internal::rml::private_worker::run()","symbolLocation":104,"imageIndex":1},{"imageOffset":9173753,"symbol":"tbb::internal::rml::private_worker::thread_routine(void*)","symbolLocation":9,"imageIndex":1},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]},{"id":457452,"name":"com.apple.NSEventThread","frames":[{"imageOffset":140705991485864,"imageIndex":0},{"imageOffset":5570,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":5},{"imageOffset":62980,"symbol":"mach_msg2_internal","symbolLocation":82,"imageIndex":5},{"imageOffset":34357,"symbol":"mach_msg_overwrite","symbolLocation":723,"imageIndex":5},{"imageOffset":6312,"symbol":"mach_msg","symbolLocation":19,"imageIndex":5},{"imageOffset":520219,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":145,"imageIndex":9},{"imageOffset":514676,"symbol":"__CFRunLoopRun","symbolLocation":1387,"imageIndex":9},{"imageOffset":511631,"symbol":"CFRunLoopRunSpecific","symbolLocation":560,"imageIndex":9},{"imageOffset":1696409,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":13},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":7},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":7}]}],
"usedImages" : [
  "size" : 0,
  "source" : "A",
  "base" : 0,
  "uuid" : "00000000-0000-0000-0000-000000000000"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 4297183232,
  "CFBundleShortVersionString" : "3.2.2",
  "CFBundleIdentifier" : "org.blenderfoundation.blender",
  "size" : 270565376,
  "uuid" : "fc0d6f3e-2258-3015-9c00-db2bb3c063f3",
  "path" : "\/Applications\/Blender.app\/Contents\/MacOS\/Blender",
  "name" : "Blender",
  "CFBundleVersion" : "3.2.2 2022-08-03"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703589138432,
  "size" : 40952,
  "uuid" : "f314b62b-98f4-3a7c-8296-8739f8b6855a",
  "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
  "name" : "libsystem_platform.dylib"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 8967520256,
  "size" : 622592,
  "uuid" : "bb7a0970-8c62-3dce-a7a2-5cec9c501f11",
  "path" : "\/usr\/lib\/dyld",
  "name" : "dyld"
  "source" : "P",
  "arch" : "arm64",
  "base" : 140703126360064,
  "size" : 196608,
  "uuid" : "d592bc4a-4a21-348f-a406-e12f9cd2f27c",
  "path" : "\/usr\/libexec\/rosetta\/runtime",
  "name" : "runtime"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703588716544,
  "size" : 237560,
  "uuid" : "7c3dcc95-9f42-3c7c-8796-476ff67b9cf7",
  "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
  "name" : "libsystem_kernel.dylib"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703587397632,
  "size" : 290804,
  "uuid" : "6282e528-6a67-334b-accf-1f8fd89369bd",
  "path" : "\/usr\/lib\/system\/libdispatch.dylib",
  "name" : "libdispatch.dylib"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703588954112,
  "size" : 49144,
  "uuid" : "5920e36f-53ec-33f0-b675-8ae48b58418c",
  "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
  "name" : "libsystem_pthread.dylib"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703753154560,
  "CFBundleShortVersionString" : "1.0",
  "CFBundleIdentifier" : "com.apple.audio.caulk",
  "size" : 155648,
  "uuid" : "66bba3ca-bce1-32f8-8269-99fac92469fc",
  "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
  "name" : "caulk"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703589355520,
  "CFBundleShortVersionString" : "6.9",
  "CFBundleIdentifier" : "com.apple.CoreFoundation",
  "size" : 4816896,
  "uuid" : "f3846a86-644b-3bcd-acce-fc7b751105c1",
  "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
  "name" : "CoreFoundation",
  "CFBundleVersion" : "1953.300"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 5205639168,
  "CFBundleShortVersionString" : "1.2.4",
  "CFBundleIdentifier" : "com.3dconnexion.driver.client",
  "size" : 49152,
  "uuid" : "01c2ba10-7831-3ab7-983f-4bb9ace2b54f",
  "path" : "\/Library\/Frameworks\/3DconnexionClient.framework\/Versions\/A\/3DconnexionClient",
  "name" : "3DconnexionClient",
  "CFBundleVersion" : "1.2.4.307"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703603720192,
  "CFBundleIdentifier" : "com.apple.Foundation",
  "size" : 10559479,
  "uuid" : "ab5f8db8-b03b-33b6-98f7-ffaec27a8eab",
  "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
  "name" : "Foundation",
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703621791744,
  "CFBundleShortVersionString" : "5.0",
  "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
  "size" : 7462910,
  "uuid" : "97a3cd09-7112-376c-9613-7f38d4cf8c41",
  "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
  "name" : "CoreAudio",
  "CFBundleVersion" : "5.0"
  "source" : "P",
  "arch" : "x86_64",
  "base" : 140703640498176,
  "CFBundleIdentifier" : "com.apple.AppKit",
  "size" : 16809984,
  "uuid" : "00f4aa78-a19f-3a8e-9650-9f90b7beefd6",
  "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
  "name" : "AppKit",
  "CFBundleVersion" : "2299.30.116"
"sharedCache" : {
"base" : 140703584993280,
"size" : 21474836480,
"uuid" : "16923f88-e9fc-38d2-947c-df242e486636"
"vmSummary" : "ReadOnly portion of Libraries: Total=881.8M resident=0K(0%) swapped_out_or_unallocated=881.8M(100%)\nWritable regions: Total=3.1G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=3.1G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               256K        2 \nActivity Tracing                   256K        1 \nCG backing stores                 5376K       12 \nCG image                            60K        5 \nColorSync                          228K       26 \nCoreAnimation                       48K        7 \nCoreGraphics                        20K        4 \nCoreUI image data                  616K        5 \nFoundation                          16K        1 \nKernel Alloc Once                    8K        1 \nMALLOC                           644.4M      119 \nMALLOC guard page                  192K        8 \nMALLOC_MEDIUM (reserved)           1.1G       11         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nOpenGL GLSL                        256K        3 \nRosetta Arena                     4096K        2 \nRosetta Generic                   1296K      321 \nRosetta IndirectBranch            1024K        1 \nRosetta JIT                      128.0M        1 \nRosetta Return Stack               920K       92 \nRosetta Thread Context             920K       92 \nSTACK GUARD                         16K        4 \nStack                             91.4M       48 \nStack Guard                        188K       44 \nVM_ALLOCATE                      144.5M      182 \nVM_ALLOCATE (reserved)           544.0M        8         reserved VM address space (unallocated)\n__CTF                               756        1 \n__DATA                            57.2M      495 \n__DATA_CONST                      16.4M      231 \n__DATA_DIRTY                       761K      123 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__LINKEDIT                       249.0M      114 \n__OBJC_RO                         65.4M        1 \n__OBJC_RW                         1985K        2 \n__TEXT                           632.8M      500 \ndyld private memory                384K        3 \nmapped file                        4.6G     1552 \nshared memory                     1340K       17 \nunshared pmap                     12.0M        9 \n===========                     =======  ======= \nTOTAL                              8.7G     4051 \nTOTAL, minus reserved VM space     6.7G     4051 \n",
"legacyInfo" : {
"threadTriggered" : {
"trialInfo" : {
"rollouts" : [
    "rolloutId" : "62fe74515312cd4599bd3c80",
    "factorPackIds" : {
      "MYRIAD_BOOSTS" : "62fe74805312cd4599bd3c81"
    "deploymentId" : 240000006
    "rolloutId" : "63582c5f8a53461413999550",
    "factorPackIds" : {
    "deploymentId" : 240000002
"experiments" : [
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Dec 26 2022, 5:07 AM
Hi, thanks for the report. This report does not contain all the requested information, which is required for us to investigate the issue.
Please carefully follow the instructions. Be sure to provide a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Please avoid copy-pasting logs in the comment. Instead upload the file itself.
