Vertex groups keep getting deleted after deselecting rigged geometry
Operating system: Windows-10-10.0.19045-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 526.98
Broken: version: 3.4.1, branch: blender-v3.4-release, commit date: 2022-12-19 17:00, hash: rB55485cb379f7
Select rigged geometry, rename geo and or object data, deselect geometry and vertex group is deleted
Video: F14143700
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jan 10 2023, 5:11 AM
HI, thanks for the report. Please upload .blend file where this happens
To specify, it's after importing a rigged .fbx or .dae model, selecting a geometry, and deselecting by clicking an empty space in the 3D viewport.
Thanks for the file. I'm not able to repro this. Could you share screen recording to demonstrate what exact is happening?
Thanks. Can you repro it with factory settings?: File โ†’ Defaults โ†’ Load Factory Settings
This comment was removed by Biggus Dickus (Why).
Pratik Borhade (PratikPB2123) closed this task as Archived.EditedJan 12 2023, 5:55 AM
Will close if factory reset has fixed the issue.
To further investigate the issue, can you disable add-on one by one to find the culprit? or was it some keymap changes causing the problem?
Edit: Just saw you deleted the comment. Does it mean you're still observing this issue?
That seems to have worked. Oddly enough, I brought back all of my startup preferences (expect for using the denoise node for compositing) and it works fine.
