Blender crushing when I want to close
Operating system: MacOS Venture M1max
Graphics card:
Blender Version 3.4.1
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Blender crashes when I worked and wanna close it
i open blender, create some stuff in form of Hard Surface Design and ( it don't happens every time but in 6 of 10 tries) doesn't matter if I save the file or not and also docent matter if I close it with cmd+Q or with File - Quit. Both ended up with an unexpected closing of Blender.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
