when starting blender 2.46 rc3 with compiz enabled the screen does not update properly. background shines through, wrong colours (see screenshot)
there is no problem when starting without compiz
compiz --version says
Checking for Xgl: present.
Checking for nVidia: not present.
Enabling Xgl with fglrx ATi drivers...
Starting kde-window-decorator
compiz 0.6.3
i'm running kubuntu 7.10 with kde 3.5 on a samsung r60plus laptop
there seems to be no problem with the current build from graphicall
= Blender 2.45 System Information =
Platform: linux2
Python:
- Version: 2.5.1 (r251:54863, Mar 7 2008, 04:14:33)
[GCC 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)]
- Paths:
/home/sbecker/temp/blender_trunk_linux_i386/blenderSVN
/usr/lib/python25.zip
/usr/lib/python2.5
/usr/lib/python2.5/plat-linux2
/usr/lib/python2.5/lib-tk
/usr/lib/python2.5/lib-dynload
/usr/local/lib/python2.5/site-packages
/usr/lib/python2.5/site-packages
/usr/lib/python2.5/site-packages/Numeric
/usr/lib/python2.5/site-packages/gst-0.10
/var/lib/python-support/python2.5
/var/lib/python-support/python2.5/gtk-2.0
/usr/lib/python2.5/site-packages/wx-2.6-gtk2-unicode
/home/sbecker/temp/blender_trunk_linux_i386/blenderSVN/.blender/scripts
/home/sbecker/temp/blender_trunk_linux_i386/blenderSVN/.blender/scripts/bpymodules
- Directories:
Blender home dir:
Default dir for scripts:
Default "bpydata/" data dir for scripts:
/home/sbecker/temp/blender_trunk_linux_i386/blenderSVN/.blender/scripts/bpydata
User defined dir for scripts:
<NOTICE> -- not found
Data dir "bpydata/" inside user defined dir:
Default config data "bpydata/config/" dir:
/home/sbecker/temp/blender_trunk_linux_i386/blenderSVN/.blender/scripts/bpydata/config
- Modules: all basic ones were found.
OpenGL:
- Renderer: ATI Mobility Radeon X2300
- Vendor: ATI Technologies Inc.
- Version: 1.2 (2.0.6473 (8.37.6))
- Extensions:
GL_ARB_multitexture GL_ARB_texture_border_clamp
GL_ARB_texture_cube_map GL_ARB_texture_env_add
GL_ARB_texture_env_combine GL_ARB_texture_env_dot3
GL_ARB_transpose_matrix GL_EXT_abgr GL_EXT_blend_color
GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_env_add
GL_EXT_texture_env_combine GL_EXT_texture_env_dot3
GL_EXT_texture_lod_bias
- Simplistic almost useless benchmark:
Redrawing all areas 10 times took 0.2770 seconds.
(*) Found 2 notices, documented in the text above.
Please mention exactly which build you got for 2.46 rc 3, and graphicall. Also, you can test if other OpenGL applications work with Compiz on your computer, this could be a driver problem.
i used blender-2.46-RC3-linux-glibc236-py25-i386.tar.bz2 from download.blender.org (display problems) and the i386 version (2008-05-03 15:29:50 rev 14668) (no display problems)
you're right about compiz. it's pretty buggy .. err .. beta .. err .. work in progress. ;-)
but the strange thing is, that the graphicall build is running without the problem.
using compiz on ubuntu hardy 8.04 works perfectly here so this is either a bug in an older compiz or a driver bug.
Either way, better to test with a newer release of compiz and file a bug to ubuntu/compiz or your the driver developers and link to this report.
