Crash while viewing alpha with internal viewer
Hey,
Had a crash in blender 2.46 on windows XP sp3. I have attached the blend file and some screenshots of what sorta error information I could dig up.
To reproduce:
- open the .blend
- split the window and open a UV/image viewer in one
- set render output to internal viewer
- set uv viewer to render result
- F12 and render using current settings
- once rendered, press the "Draw alpha only" button
- crash!
NOTE: the gdb was on an svn copy since I didnt have debug info in the release
Let me know if you need more info
troubled@freenode
Another thing I forgot to mention, hitting the "a" key on the external render window works fine, I only get a crash when I use the button in the internal viewer.
I couldn't redo the problem on Ubuntu Linux 64bit and Windows XP. It might be an opengl issue due to graphics driver differences. Can you test if drawing the z buffer also crashes (button right next to draw alpha) ?
No, clicking that button didnt do it, but I noticed something else. If I just start blender up and go right to reproducing it crashes like usual, but if I click the other two buttons sveral times in random orders and then click the alpha button, I got it to work once and it stayed working. Even after I kept blender running and reopened the file and tried just the alpha, it worked. But as soon as I close blender and tried again, it went back to crashing.
Worth mentioning, I am using slightly older Ati video drivers to work around the Ati gl select slowdown bug. Also, if you need a video recording or something of what im doing, let me know.
I can't reproduce it in linux and blender svn revision 15360, maybe windows realted only
I just checked with Windows Vista on current svn, didn't crash.
Dan: the 'draw alpha only' uses a nice opengl feature, that one might cause your problem. It is basic but uncommon opengl, probably only supported when your drivers are good.
Ton,
Sorry, but I was offline for a fortnight while I changed addresses and its been a little busy around here. I only came back online in irc recently (aka troubled) and I am still playing catch up.
Before I left though, I did upload the broken twit.blend file to show you the files. I was told not to upload the blend without trimming it first, but some of the devs grabbed the one I uploaded to the public ftp a few weeks ago (you gave me the http address to the uploads remember?).
Anyways, I chatted with a few of the guys on irc the other day and we figured it was just a graphics driver issue with my card. I will try again on a clean install or vm and let you know what I get when I have a chance.
Sorry for the confusion and delay! :)
PS - This reply will be used for the other bug as well as we assume its the same problem.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:38 AM
