I have created a mesh which behaves as expected under Mac OSX. And which seemed to work also OK under Fedora 9 until recently. Under Fedora 9, it now renders as all purple (Depth 0 is the material name) when activating the flat Z shading (Solid) model in the 3d window. When I change to Shaded or Textured, it shows all the 10 colors that are assigned to the mesh.
I expect that this is a problem with Fedora, not Blender, but want to see whether it could possibly be a bug in the way that Blender is using OpenGL codes.
Comment Actions
I tried it with Ubuntu 8.04 and Shift-Z (Shading) shows all colors. This is with an nvidia card and nvidia proprietary drivers 169.12.
Comment Actions
Yeah, we had this reported once before... switching material color is a very basic OpenGL feature, but sometimes not tested inbetween releases.
Michael: just try older or newer drivers, and you're most likely set! :)
Comment Actions
