Armature not rendered in 3D Viewport window render
When the button in the 3D Viewport header is pessed to render the 3D Viewport contents, ordinary armature bones are not rendered. Paths and custom bones are rendered, but ordinary octagonal bones disappear.
I'm assuming that this is in svn-trunk, and that this used to work ok for you.
Is there any grease-pencil drawing anywhere?
This is in 2.47 RC 2 for Windows. In 2.46, armatures were visible in renders made with the viewport render button.
There is no grease-pencil. To be sure, I tried this on a brand new .blend with nothing but a default cube and an armature bone, and the bone does not render.
Hmm... can't reproduce this error here (windows, svn-trunk) using the drivers on this machine. However, when running using MesaGL as the OpenGL renderer, I can replicate this bug.
Can't reproduce on two different linux machine (nvidia drivers)
Just for the record, I discussed this further on IRC, and noted that octohedrons, b-bones, and envelopes do not render, but custom bones and sticks do render.
My computer's graphic card does not support GLSL. Aligorith tested using MesaGL and was able to reproduce the bug.
Confirmed error here, osx 10.3. System didnt change for years, and has rock stable opengl.
It works fine in older blender ;)
There was an issue introduced after this bug report where armatures wouldn't render at all in the opengl render irrespective of the graphics card. This was fixed.
However the original bug is probably still not fixed, since I only reverted the behavior from before. I tried redoing it in the official 2.47 and 2.47-static version, and latest svn, but no luck. This was with both nvidia drivers and MesaGL, version 1.4 (2.1 Mesa 7.0.3-rc2). So I'm assigning this back to Joshua since he was able to redo.
I think I've finally found that this is a driver issue.
Mesa-7.0.4 had this problem, but it was resolved in Mesa-7.2.
Closing now!
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:38 AM
