this patch adds a context function to retrieve the "mode string" and make them available to python so that view3d header can have python menus
it's just a first pass to see if I get it right...
what I've done so far:
- created CTX_data_mode_string() to find out what mode we're in (accessible as a string from RNA as context.mode_string)
- wrapped view3d_header.c:view3d_select_*menu() so they can be used from python as layout.view3d_select_*menu()
- defined view3d "select" menus in python (using wrapped functions)
- moved mode-switch for select menus from view3d_header.c:view3d_header_pulldowns() to python
- implemented the "select" menu for mesh editmode in python as a test
new version of the patch
all "Select" menus have been implemented in python
editmode_armature and posemode still need the C function... is there a way to use uiItemFullO from python?
Instead of checking the mode_string with if/elif the header now lookup the menu by name, to do this I had to change the strings in CTX_data_mode_string(), some of them where too long and the resulting bpy.types.Menu class names didn't get registered.
another update
- rebased to rev 22472
- I've removed C functions that have been ported to python
- select menus are looked for in bpy.types instead of static list
- there's an error in objectmode select menu that I haven't looked into yet (uiItemEnumO_string: OBJECT_OT_select_grouped.type, enum not found.)
