Starting
I can't start blender 2.50 svns. The console start but, before all, an error occured !
Please specify your operating system, which build you are using, and most importantly, what the error message is?
Closing due to lack of information, can be reopened if more is provided.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.Nov 11 2009, 11:19 AM
This error is happening with the svns. The last is http://www.graphicall.org/builds/builds/showbuild.php?action=show&id=877.
The error is :
AppName: blender.exe AppVer: 0.0.0.0 ModName: blender.exe
ModVer: 0.0.0.0 Offset: 00403e3a
It's very strange because others builds run correctly (for instance : http://www.graphicall.org/builds/builds/showbuild.php?action=show&id=1169)
Sorry if I don't speak English very well. I'm French
Thank you !
The first link has these instructions, did you install the runtime?
Make sure you have the MS Visual C++ Runtime installed on your computer. Otherwise, Blender maybe fails on start.
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=a5c84275-3b97-4ab7-a40d-3802b2af5fc2
Yes, it is installed !
But I'm not sure the Runtime of 2005 is installed.
I think it is not necessary !
If that build is made using Visual Studio 2008, you do need the 2008 version of the runtime installed.
The 2008 version SP1 is installed !
Maybe this helps?
http://www.blender.org/forum/viewtopic.php?p=74914&sid=2dc64d3a5fce9390ca3a57c13e4ea6bd
But further, we can't support unofficial graphicall builds, if one works and another not, that means it's some problem in how the build is made, and that is not under our control.
