Click and drag a button (say "End Frame" in Render Settings) to the right a bit and back to the left. It doesnt go back to down to the original Frame Number, but hangs somewhere around 20 Frames above the original one.
I would suspect that is the Frame number where the cursor is, when it exits the screen, and cant enter it anymore ..
Cheers
Alex,
What is your OS (and the svn version you were using when finding this bug) ?
I can't reproduce this issue on OSX.
Cheers,
Damien
Rev25214, ubuntu 9.10 32 bits, ati HD4200, proprietary drivers
cannot reproduce this either on my computer
regards
well obviously someone with vista 32 bit should be able to reproduce it .. not someone with ubuntu!?
I'm experiencing some weird behaviour here on vista 32 bits. If I slide the end frame button to the right, the number increases. While holding down the mousebutton and slide it back to the left, it doesn't go back, but indeed seems to stick. This happens when you slide it back fast. Sliding it back very slow "sometimes" enables me to slide all the way to the left.
Please try to reproduce it with this file where the properties view is not directly on the window edge.
http://www.pasteall.org/blend/1358
Seems to work fine under Linux, so the bug is probably in Ghost. Would need someone to check on OS X to confirm this.
@Matt,
same problem with the sample file. (contgrabtest.blend)
i drag to the right and cant drag all the way back to the left.. it gets stuck
cheers
On Windows 7 Ultimate 64bit I am unable to reproduce this behaviour. I can increase and decrease values across areas both with and without continous grab enabled.
Could you try with a recent Windows build? Ie. http://www.letworyinteractive.com/b/ - I updated my builds tonight to r31618.
hi!
jupp still not working with r31618. windowed mode works, fullscreen mode doesn't. (with fullscreen i don't mean the blender fullscreen button, but the microsoft windows top tab double click ;-) ) As a matter of fact, in blender button fullscreen mode it works!
Win 7 Home Premium 64 bit.
cheers
Ok, after trying again I can now reproduce this error even with latest Blender 2.54 beta release. Thanks for being persistent. Now to see if a fix can be found...
