animated node values haven't effect while render animatión
If you animate composite node values (no matter what) they update ok on the screen and render ok whith F12 (one image), but if you render an animation, all nodes are frozen.
I hope some coder can check this frame updater bug for animated nodes.
Blender 2.5 (x86_64), latest svn, OS X Snow Leopard.
Mac pro, Nvidia gtx285
Thanks in advance.
Hi again ;)
I found a workaround what may help you to find the bug:
If you add a node of type "Render Layers" (even if not used like on my example), the rendered animation is OK.
Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.
Matt Ebb (broken) changed the task status from Unknown Status to Resolved.Jan 13 2010, 4:24 AM
