Anti-alasing + comp nodes crashing blender on re-render
running rev 26380
Sometimes when re-rendering a scene with anti-alas > 5 blender crashes. Does not occur if the temp folder is cleared.
windows 7, 64bit
4 gig ram
AMD turion x2 dual core RM-70 2.0Ghz
Hi, I can't reproduce this here on rev. 27340.
Please attach a simplified test file that can be used to reproduce the problem, as mentioned in the bug reporting guidelines.
thanks
You can close this, it doesn't happen anymore to me either. Earlier it happen on just the default cube.
Great, I'll close this then.
Please reply back to this report if you find the problem again with a repeatable test file, and I'll re-open it.
Matt Ebb (broken) changed the task status from Unknown Status to Archived.Mar 10 2010, 12:23 AM
