Steps to reproduce:
- Use the attached .B25.blend as the default configuration file (ie. copy the file into $home/.blender/ or whatever place it should be in)
- Start Blender
- Use Alt + Left Mouse to rotate the 3d view: this works
- Use Left Mouse to drag a border: works as well
- Now press Alt + Tab to switch to another window (I've only tested other OS windows, not Blender windows)
- Use Alt + Tab again to switch back into the Blender window
- Try to use Alt + Left Mouse to rotate the 3d view again
It will now do border selection (ie. what's assigned to the Left Mouse shortcut, without key modifiers) instead of rotating the view ("view3d.rotate" is assigned to Alt + Left Mouse in the attached .B25.blend).
Only after clicking with the Left Mouse button again, it will return to the assigned behavior from the key configuration.
Normally, this bug will go unnoticed because the default Blender keymap configuration doesn't have such shortcuts (as far as I know), it will only show up with settings as in the attached file. These settings make Blender's behavior a little more like programs such as Silo or Maya.
For me, the bug shows up when using Blender 2.5 (latest svn) on Windows (Vista, SP1). I don't know if it happens on Linux and/or OSX as well.
Comment Actions
http://projects.blender.org/tracker/index.php?func=detail&aid=21158&group_id=9&atid=498
Is a bit similar to this type of bug, though it seem to be a Mac issue there, or is it?
Comment Actions
I've been having strange modifier key hanging issues on Mac, and focus issues on Linux recently, but wasn't able to redo them. I suspect this is caused by the drag & drop commit that included some changes for handling events even if the window is out of focus. So for anyone who wants to debug this, testing if there is a difference before and after r26310 may be a good start.
Comment Actions
Was able to redo this on windows before, but seems to be working ok in latest svn, so closing report.
