Summary: Having a project set up to a particular resolution will shift when you choose certain encoding parameters. For example, changing the encoding format to FFMpeg will suddenly change your resolution to 720x480. One would expect that only the Dimensions panel should invoke changes in resolution.
Version: SVN 27140
Platform: Linux amd64 (Ubuntu 9.10)
Comment Actions
Confirmed, calling some weird preset code that doesn't belong there. Probably should migrate it to python preset system for FFMPEG outputs.
Assigning to self, will fix soon.
Comment Actions
Still looks like the dimensions are changed when you select from the "Presets" group box under Encoding.
