Line Sample Tool & Histogram show linearised output when Colour Management is enabled. Gamma corrected when CM disabled.
Load a gamma encoded 2.2 image into node editor. Open scopes panel in UV/Image Editor. Render, (needs camera for compositor, argh!!) :-)
With CM off histogram and Line Tool scopes for render result shows 2.2 gamma output.
With CM on histogram and Line Tool scopes for render result shows what appears to be linearised output.
Render output is still gamma 2.2 as it should be. Scopes incorrect.
Line tool doesn't update with render result change, histogram does.
Luma scope in VSE exhibits same problem when activating 'Convert Float'.
As mentioned in a previous report, this is on the todo list, so closing this report.
Matt Ebb (broken) changed the task status from Unknown Status to Archived.Mar 26 2010, 8:03 AM
