When Blender 2.5 r27832 is run from a network share most of the user interface text is missing and the menu does not show up.
The output in the text window is as follows:
RNA_string_set: OperatorProperties.value_2 not found.
search for unknown operator WM_OT_context_toggle_enum, WM_OT_context_toggle_enum
RNA_string_set: OperatorProperties.path not found.
RNA_string_set: OperatorProperties.value_1 not found.
search for unknown operator WM_OT_context_cycle_enum, WM_OT_context_cycle_enum
search for unknown operator WM_OT_context_toggle, WM_OT_context_toggle
search for unknown operator OBJECT_OT_subdivision_set, OBJECT_OT_subdivision_set
RNA_int_set: OperatorProperties.level not found.
RNA_boolean_set: OperatorProperties.relative not found.
search for unknown operator WM_OT_context_set_int, WM_OT_context_set_int
RNA_int_set: OperatorProperties.value not found.
search for unknown operator WM_OT_context_scale_int, WM_OT_context_scale_int
RNA_float_set: OperatorProperties.value not found.
search for unknown operator WM_OT_context_set_enum, WM_OT_context_set_enum
RNA_string_set: OperatorProperties.value not found.
search for unknown operator WM_OT_context_cycle_int, WM_OT_context_cycle_int
RNA_boolean_set: OperatorProperties.reverse not found.
search for unknown operator CONSOLE_OT_execute, CONSOLE_OT_execute
search for unknown operator CONSOLE_OT_autocomplete, CONSOLE_OT_autocomplete
search for unknown operator HELP_OT_release_logs, HELP_OT_release_logs
search for unknown operator HELP_OT_manual, HELP_OT_manual
search for unknown operator HELP_OT_blender_website, HELP_OT_blender_website
search for unknown operator HELP_OT_user_community, HELP_OT_user_community
search for unknown operator HELP_OT_python_api, HELP_OT_python_api
Mapping a drive letter to the network share and running blender from the mapped drive works around this problem.
The problem is the work around is not obvious.
If I double click on the Blender executable it should just work
This is not really a Blender Problem, more a problem of your system/configuration I guess. For some Reason the blender binary doesnt fint the script folder.
I use Blender 2.5.2 SVN myself in a windows network, starting it from a network share too, without problems. There shouldn't be any problems, when your script folder is where it should be.
Regards,
DingTo
It doesn't work on either my 2003R2 or XP SP3 machines running off a windows 7 network share but it does work when I map the drive to the exact same share.
Where in the source should I look to find where it is looking for it's resources? I've come across this problem in other software and it's usually caused by a slightly malformed pathname which new versions of windows correct but older versions return an error.
