svn28053
in "texture paint" mode the "external editing" doesn't open the editor, the path is set correctly on the .exe file of photosop but no way.. also gimp with gimp I have the same problem.
thankyou! ^^
Hi, I can't reproduce this on Mac OS X 10.5.8, svn revision 28057.
I take it you are using Japanese language Windows? I'm not sure what the 'yen' symbols in the paths might cause... Are you able to test this on another system set to english language?
Another question: Does this happen while working on a file that you have already saved? Or is it only on the default cube startup scene before saving?
I will try tonight on english version windows(7).
Happen in both of case.
The strange thing is that few svn ago the external painting tool woked fine :S
thankyou!
Ok, also at home with win7-64bit in english I have the same problem.
I attached another image of the console, I tried with photoshop gimp and mypaint but no way.
I made various ests, with already saved file, with new file, with default cube, with mokey, with other meshes... but I still have the problem.
Hi, Martin Poirier just committed a fix to svn that should hopefully make this work. Can you please try this again on an updated svn revision (higher than rev. 28143) and see if it works?
thanks.
