Fix to [#21938] File Browser: Not showing folders with spaces
Closed, ArchivedPublicPATCH
This allows navigating through Reparse Points in windows Vista and 7. I'm not a c hard coder so the code may not be "clean" or it may not be totally multi-platform aware (I had a look to other code and used #ifdef WIN32 for the WIN32 platform but it may be wrong).
Also It may not work for Xp due to the use of GetFinalPathNameByHandle. Please check.
For the blender file browser to behave as the windows one the "real" folders should be masked (i.e. you only see "Usuarios" and not "Users" folder in spanish) but that may be done in other patch.
Regards,
Ignacio
Thanks for the patch I tried it here on Windows Vista and it works fine.
Unfortunately it doesn't work on Windows XP, so we have to find a way to make this available in newer versions of Windows only without having to create separate executables and installations.
Have a look at this article on MSDN Obtaining a File Name From a File Handle http://msdn.microsoft.com/en-us/library/aa366789%28v=VS.85%29.aspx.
If you cannot use that to make it work on XP, use
OSVERSIONINFOW OSVersion;
ZeroMemory(&OSVersion, sizeof(OSVERSIONINFO));
OSVersion.dwOSVersionInfoSize = sizeof(OSVERSIONINFO);
GetVersionEx(&OSVersion);
If(OSVersion.dwMajorVersion >= 6)//its vista or higher
See MSDN article http://msdn.microsoft.com/en-us/library/ms724832%28v=VS.85%29.aspx
Thanks for the code, Richard. Unfortunately i can't compile Blender now due to the pthreads.h error so i can't try it until i fix that. Can you add it to the patch and test?
New patch (patch_vista.txt). Added function to check if the Windows version is one given or later so now the new code should not run for Xp and earlier (can't try so please check).
Hi Ignacio,
Turns out that still doesn't work on XP because blender is trying to load GetFinalPathNameByHandle() from the dll when it starts(Which doesn't exist in the XP dll so it causes a error and crash). Other than that its fine. However I did find this Tutorial http://www.dreamincode.net/forums/topic/118076-dlls-explicit-linking , I'll try it out and see if I can get it to load this way.
Hi Richard,
Didn't think of that. Let me know if you find something but if there is no way to skip that load two separate builds will be needed or a way to get the reparse point addres without using that function.
Maybe there is a way to fake that function when is not present in xp and earlier as it won't be used anyway, but i don't know how to do that.
Hi Ignacio,
Managed to get this working on Vista and not crashing on XP see updated patch here http://docs.google.com/View?id=dd299srs_31g3g7km4j. I've added in
#ifdef __MINGW32__
#define _WIN32_WINNT 0x0500
#endif
so it will build on minGW(as well as visual studio), but I doubt this is how this should be done. Other than that there aren't any other problems that I've found.
Hi Ignacio, Hi Richard,
I've got a bit of time on my hand in the next days or so and would like to attempt to fix this issue. Unfortunately I can't get to the updated patch on docs.google.com anymore - could you attach the latest patch here on the tracker? (I know it's been a long time...)
Cheers,
Andrea
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Aug 4 2014, 1:54 PM
Seems time to archive this one, org report has been closed since ages too…
