Crashes when attemp to use openexr or multilayer exr image as input node *NEED RE-TEST*
Intel Core i7
Windows 7 Professional 64 bit
ATI Radeon HD 5800 Series
Blender 2.5
2.52.5
r'28201
Blender crashes when I attempt to use an open exr or multilayer exr as an input and attach it to a viewer. It happens every time even in an empty blend file.
Also happens when I attach it to the composite node but only after more than one connection hasd been made (i.e. image and alpha, or immage and Z)
Probably useless but here is the windows crash information
Problem signature:
Problem Event Name: APPCRASH
Application Name: blender.exe
Application Version: 0.0.0.0
Application Timestamp: 4bc6dd09
Fault Module Name: blender.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4bc6dd09
Exception Code: c0000005
Exception Offset: 000000000046c000
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 2057
Additional Information 1: 68f5
Additional Information 2: 68f5069f6a7d6b6b62bb281befdc58ed
Additional Information 3: 5382
Additional Information 4: 5382fdce189ea344b6b641656d3e258e
Apologies if this has already been reported I couldn't find it in the list.
Can't reproduce this here on osx / revision 28201.
Can you try this with a different build? If you compile your own, maybe try one from www.graphicall.org? Does this happen in the official alpha 2 release? It sounds to me suspiciously like a problem with the openexr library your build may have been built with...
Closing this report due to insufficient information (eg. lack of
test file, steps to reproduce, ...).
If you can reply to this report and provide this information, we
can re-open it to investigate.
Apologies for the lack of communication I have been away.
I have tried with the official 64-bit alpha 2 release and with 64-bit trunk builds from graphicall and the same happens. Saving as OpenExr is okay (but doesn't allow for Z-layers as far as I can tell) but saving or loading (or doing anything) with MultiLayer images causes this error in the console window with whichever build I use.
ImportError: No module named _socket
Error: can't process EXR multilayer file
DDS: not valid; header follows
Flags: 0x6E656C42
DDSD_HEIGHT
Height: 1299342692
Width: 1769237621
Depth: 7103854
Mipmap count: 1769108595
Pixel Format:
Flags: 0x65520000
FourCC: 'nder'
Swizzle: 'Laye'
Red mask: 0x6F432E72
Green mask: 0x6E69626D
Blue mask: 0x412E6465
Alpha mask: 0x00000200
Caps:
Caps 1: 0x00000000
Caps 2: 0x00000100
Caps 3: 0x00000100
Caps 4: 0x6E655200
Unknown fileformat
libpng error: Image width or height is zero in IHDR
Then when I try to composite (I'm trying to use a Z-combine), blender crashes completely.
However after a huge amount of retesting I have realised this only happens (i.e. the full crash) when I turn colour management off in the shading options. I have attached an example blend file ready to test but please let me know if you need anything else.
Flags: 0x6E656C42
DDSD_HEIGHT
Height: 1299342692
Width: 1769237621
Depth: 7103854
Pixel Format:
Flags: 0x65520000
FourCC: 'nder'
Swizzle: 'Laye'
Caps:
Caps 1: 0x00000000
Caps 2: 0x00000100
Caps 3: 0x00000100
Caps 4: 0x6E655200
Unknown fileformat
Thanks for replying back, can any other win64 users reproduce this?
Not a Win64 user, but i can confirm this on Ubuntu 10.04, SVN 28714
As already stated by Daniel, the crash only happens with Multilayer files and only if color management is turned off while connecting the image-node to the viewer.
Also note that the the image-node itself - without a connection to the viewer - doesn't show any thumbnail preview when loading the file with color management turned off. With color management turned on, everything works.
I can't attach a file to this bug, so i am pasting my backtrace here:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0xab1d3b70 (LWP 24859)]
do_copy_rgba (node=0xb3536a30, out=0xa6f54020, in=0x0) at /build/buildd/blender-2.52.5~svn28714/source/blender/nodes/intern/CMP_util.c:703
703 in /build/buildd/blender-2.52.5~svn28714/source/blender/nodes/intern/CMP_util.c
(gdb) thread apply all bt
Thread 911 (Thread 0xab1d3b70 (LWP 24859)):
#0 do_copy_rgba (node=0xb3536a30, out=0xa6f54020, in=0x0) at /build/buildd/blender-2.52.5~svn28714/source/blender/nodes/intern/CMP_util.c:703
#1 0x08a2c89a in composit1_pixel_processor (node=0xb3536a30, out=0xab38ea8, src_buf=0xab72e18, src_col=0xab4f310, func=0x8a29320 <do_copy_rgba>, src_type=4)
at /build/buildd/blender-2.52.5~svn28714/source/blender/nodes/intern/CMP_util.c:459
#2 0x08a2e1ac in node_composit_exec_viewer (data=0xb1621758, node=0xb3536a30, in=0xab1d31c0, out=0xab1d30c0) at /build/buildd/blender-2.52.5~svn28714/source/blender/nodes/intern/CMP_nodes/CMP_viewer.c:93
#3 0x089cd8fa in exec_composite_node (node_v=0xb3536a30) at /build/buildd/blender-2.52.5~svn28714/source/blender/blenkernel/intern/node.c:2264
#4 0x08a92f22 in tslot_thread_start (tslot_p=0xab1c2f8) at /build/buildd/blender-2.52.5~svn28714/source/blender/blenlib/intern/threads.c:213
#5 0xb7e1696e in start_thread () from /lib/tls/i686/cmov/libpthread.so.0
#6 0xb69c2a0e in clone () from /lib/tls/i686/cmov/libc.so.6
Thread 910 (Thread 0xb1faeb70 (LWP 24858)):
#0 0xb7fe2430 in __kernel_vsyscall ()
#1 0xb698cce6 in nanosleep () from /lib/tls/i686/cmov/libc.so.6
#2 0xb69bc44c in usleep () from /lib/tls/i686/cmov/libc.so.6
#3 0x08aaa918 in PIL_sleep_ms (ms=50) at /build/buildd/blender-2.52.5~svn28714/source/blender/blenlib/intern/time.c:94
#4 0x089ce93e in ntreeCompositExecTree (ntree=0xb35d0968, rd=0xb1621758, do_preview=1) at /build/buildd/blender-2.52.5~svn28714/source/blender/blenkernel/intern/node.c:2485
#5 0x0877b584 in compo_startjob (cjv=0xb35310c8, stop=0xb3541be0, do_update=0xb3541bde) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/space_node/node_edit.c:156
#6 0x085f63d1 in do_job_thread (job_v=0xb3541b98) at /build/buildd/blender-2.52.5~svn28714/source/blender/windowmanager/intern/wm_jobs.c:197
#7 0x08a92f22 in tslot_thread_start (tslot_p=0xb3501d38) at /build/buildd/blender-2.52.5~svn28714/source/blender/blenlib/intern/threads.c:213
#8 0xb7e1696e in start_thread () from /lib/tls/i686/cmov/libpthread.so.0
#9 0xb69c2a0e in clone () from /lib/tls/i686/cmov/libc.so.6
Thread 17 (Thread 0xb0918b70 (LWP 23947)):
#1 0xb69b4b86 in poll () from /lib/tls/i686/cmov/libc.so.6
#2 0xb4e2c502 in ?? () from /usr/lib/libpulse.so.0
#3 0xb4e18a59 in pa_mainloop_poll () from /usr/lib/libpulse.so.0
#4 0xb4e1aa13 in pa_mainloop_iterate () from /usr/lib/libpulse.so.0
#5 0xb4e1aae4 in pa_mainloop_run () from /usr/lib/libpulse.so.0
#6 0xb4e2c2a3 in ?? () from /usr/lib/libpulse.so.0
#7 0xb4aa7e02 in ?? () from /usr/lib/libpulsecommon-0.9.21.so
Thread 1 (Thread 0xb4955760 (LWP 23931)):
#0 0x08941dc1 in BKE_icon_get (icon_id=31) at /build/buildd/blender-2.52.5~svn28714/source/blender/blenkernel/intern/icons.c:264
#1 0x085fdb04 in icon_draw_size (x=617, y=5, icon_id=31, aspect=1, alpha=1, rgb=0x0, miplevel=0, draw_size=16, nocreate=0) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface_icons.c:897
#2 0x085fe003 in icon_draw_mipmap (x=617, y=5, icon_id=31, aspect=1, alpha=1) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface_icons.c:994
#3 UI_icon_draw_aspect (x=617, y=5, icon_id=31, aspect=1, alpha=1) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface_icons.c:999
#4 0x08615bf1 in widget_draw_icon (but=0xb35ca678, icon=ICON_ZOOMIN, alpha=1, rect=0xbfffef7c) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface_widgets.c:791
#5 0x086163ba in widget_draw_text_icon (fstyle=0xbffff034, wcol=0x9c57228, but=0xb35ca678, rect=0xbfffef7c) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface_widgets.c:1038
#6 0x08618369 in ui_draw_but (C=0x9d06468, ar=0xb35eab28, style=0xbfffef8c, but=0xb35ca678, rect=0xbfffef7c) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface_widgets.c:2783
#7 0x08631108 in uiDrawBlock (C=0x9d06468, block=0xb35548d0) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/interface/interface.c:762
#8 0x0866e3dd in ED_region_header (C=0x9d06468, ar=0xb35eab28) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/screen/area.c:1445
#9 0x087261c4 in info_header_area_draw (C=0x9d06468, ar=0xb35eab28) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/space_info/space_info.c:143
#10 0x0866fc9a in ED_region_do_draw (C=0x9d06468, ar=0xb35eab28) at /build/buildd/blender-2.52.5~svn28714/source/blender/editors/screen/area.c:350
#11 0x085e3264 in wm_method_draw_triple (C=0x9d06468) at /build/buildd/blender-2.52.5~svn28714/source/blender/windowmanager/intern/wm_draw.c:578
#12 wm_draw_update (C=0x9d06468) at /build/buildd/blender-2.52.5~svn28714/source/blender/windowmanager/intern/wm_draw.c:729
#13 0x085e00a8 in WM_main (C=0x9d06468) at /build/buildd/blender-2.52.5~svn28714/source/blender/windowmanager/intern/wm.c:342
#14 0x085dee11 in main (argc=1, argv=0xbffff384) at /build/buildd/blender-2.52.5~svn28714/source/creator/creator.c:1061
ubuntu 10.04, 64bits, rev32053
No more problem.
Can you please see if this bug still happens to you as there have been quite many fixes recently around color management and exr files?
No crash here r32698, could you please test with a recent build?
tagged as needing to be tested again.
I still have the same problem with the offical beta release from the website. Haven't tried to do a build of my own for a while.
There will be a new beta soon, so I'll keep this report open until that. Please test as soon as you can when the new beta is available and report back here!
No response from submitter, so closing the report.
Janne Karhu (jhk) changed the task status from Unknown Status to Archived.Nov 15 2010, 11:53 AM
