Render freezes in rev 28521, 64-bit version of alpha 2 on Win 7 x64
To reproduce:
From a clean install, open Blender and hit F12. The app freezes. I also tried changing the render to New Window and Image Editor with the same result.
The previous (27258) 64 bit version works fine as does 28522, 32 bit version.
I'm running Windows 7 pro x64 with an Nvidia Quadro FX 880M graphics card with 1GB of dedicated memory.
I'm having this same problem on Windows 7 Ultimate 64 with an ATI Mobility Radeon HD3470
What exactly do you mean by freeze - does it just stop responding to input? Or actually crash?
Doesn't happen here on OS X, rev. 28523, so might need a windows dev to confirm/test here.
It stops responding to input.
Ok - also, is this one that you built yourself? Or perhaps a specific build from online (graphicall etc?)
The revs I mentioned were BF builds on Grahicall.
Same problem on Windows Vista 64 bit with graphicall r28858.
I check the process with task manager and it use not CPU and memory is stable.
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: blender.exe
Application Version: 0.0.0.0
Application Timestamp: 4bdc2cef
Hang Signature: c847
Hang Type: 0
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 4105
Additional Hang Signature 1: b2d2f7ec2af7f2225d0872440fde753e
Additional Hang Signature 2: 08eb
Additional Hang Signature 3: 138219a7d585df0bb1da83da9068aa28
Additional Hang Signature 4: c847
Additional Hang Signature 5: b2d2f7ec2af7f2225d0872440fde753e
Additional Hang Signature 6: 08eb
Additional Hang Signature 7: 138219a7d585df0bb1da83da9068aa28
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Just hit F12 to render the default scene.
Hope this help
I forgot to say that on Ubuntu 9.10 64 bit this problem don't happens
Hi, just checking up - is this problem still happening on up-to-date SVN builds?
I can confirm that as of rev 28861 it I can render the default scene without problems in full screen and new window. I'd say it's fixed. Thanks!!!!
Excellent, I'll close this then.
Thanks
Matt Ebb (broken) changed the task status from Unknown Status to Resolved.May 27 2010, 3:30 AM
