after using loop cut and slide the maximize, minimize, and close Windows buttons stop working
After using loop cut and slide the maximize, minimize, and close Windows buttons stop working.
Open default scene.
Press ctrl+r in edit mode to loop cut and slide.
After applying, the the maximize, minimize, and close Windows buttons stop working.
How do you execute and confirm the loop cut? You press ctrl R, click once to choose an edge loop, then click again to confirm? Or (if you have 'release confirm' enabled) click, or click+drag to confirm? Are there any other symptoms of this problem apart from the windows title bar widgets not working?
I'm closing this report due to lack of response - if you can provide more info that can help reproduce/diagnose this bug (like the question above, or screen recordings, etc), please reply here and I can re-open the report.
thanks
Matt Ebb (broken) changed the task status from Unknown Status to Archived.Jun 15 2010, 3:40 AM
