Strange bug when minimizing using the task-bar, the same does not happen when using the upper right minimize button, and neither when switching to another program - only when minimizing by clicking the blender process in the windows task-bar.
Steps to reproduce:
* Start blender
* Split the 3d viewport horizontally by dragging in the corner from right to left
* Click the process in the task bar to minimize
* Click again to maximize
* Crash
System info:
* Windows XP Pro (32 bit)
* Intel Core2 Duo U9400
* GPU: Mobile Intel(R) 4 Series Express Chipset Family
Not sure what exact GPU this is, extract from dxdiag below
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_20E417AA&REV_07
Display Memory: 1024.0 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4957 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/11/2008 11:15:36, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 6/11/2008 11:15:38, 6021184 bytes
Device Identifier: {D7B78E66-6902-11CF-4767-EE00A6C2CB35}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x20E417AA
Revision ID: 0x0007
Revision ID: 0x0007
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Hi,
Seems like a driver problem and related to windows.
The system information is fine but, can you post a backtrace of the crash ?
Nathan, can you take a look at this ?
Thanks,
- Diego
Yes you are right, it seems like a driver problem. I have attached my gdb session. Problem is with ig4dev32.dll - installed version is 6.14.10.4957. Unfortunately I can't try other driver versions because of corporate policy on this computer.
If there is anything more I can provide, please let me know.
Hi,
Really nothing we can do here, it's a driver problem and not Blender.
I close the report now. If you can update the driver and found more information that can help us to make a "work around" for this class of error, please reply this report and I will reopen it.
Thanks,
- Diego
