User interface text becomes invisible (see attached screenshot). This happens quite often for me at seemingly "random" times, however I managed to find a way to reliably reproduce it. Sometimes the text will re-appear after fiddling around, but the text will then look corrupted - leading me to believe this might be related to bug #19997
Steps to reproduce:
* Start blender with defaults
* Select user-preferences from file menu
* Go to file and choose any file browser, text will now dissappear from the blender UI
* Immideately close the file browser with the [X] in the upper corner
* UI text remains invisible
If instead of closing the browser, you select a file/directory the text will sometimes re-appear correctly.
As mentioned this will also happen at other seemingly random times.
System info:
* Windows XP Pro (32 bit)
* Intel Core2 Duo U9400
* GPU: Mobile Intel(R) 4 Series Express Chipset Family
Not sure what exact GPU this is, extract from dxdiag below
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_20E417AA&REV_07
Display Memory: 1024.0 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4957 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/11/2008 11:15:36, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 6/11/2008 11:15:38, 6021184 bytes
Device Identifier: {D7B78E66-6902-11CF-4767-EE00A6C2CB35}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x20E417AA
Revision ID: 0x0007
Revision ID: 0x0007
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Hi,
Seems to be the same bug that #19997, can you test with differents OpenGL options ?
ctrl+alt+u -> system -> windows draw method
Please try with differents options to see what happend.
Thanks,
- Diego
Problem is present with all options: Full, Overlap Flip, Overlap, Triple buffer and Automatic.
Overlap seems to have more problems on my system and doesn't re-draw correctly.
Hi,
I have the same issue with r29532. Each time I open a sub-window, like the user prefs or render in a new window, the main blender window text and/or icons are corrupted or missing.
I however found a way to get the display back to normal: close the sub-window and turn full screen (ALT + F11) a few times.
The issue appears on my 2 computers:
Laptop:
- Processor: Intel Core2 Duo P8400
- Graphic card: Intel Mobile 4 series express chipset
- OS: Windows XP Pro SP3 32 bits
Desktop:
- Processor: Intel Core2 Duo E6300
- Graphic car: ATI Radeon HD 5770
Hi,
Seems to be a problem with the drivers and windows XP 32 bits.
Nathan, can you take a look at this ? there is something we can do ?
Thanks,
- Diego
Duplicate of this bug:
http://projects.blender.org/tracker/index.php?func=detail&aid=19997&group_id=9&atid=498
OpenGL texture gets lost on duplicating window, something to do with OpenGL contexts probably.
