Windows XP Pro SP3
Building with cmake 2.8 + Visual Studio 2008 Express
openjpeg enabled does not build; error:
dwt.c
..\..\..\build\trunk\blender-2.5\extern\libopenjpeg\dwt.c(613) : error C2088: '*' : illegal for union
..\..\..\build\trunk\blender-2.5\extern\libopenjpeg\dwt.c(625) : error C2088: '+' : illegal for union
..\..\..\build\trunk\blender-2.5\extern\libopenjpeg\dwt.c(632) : error C2088: '+=' : illegal for union
..\..\..\build\trunk\blender-2.5\extern\libopenjpeg\dwt.c(633) : error C2088: '*=' : illegal for union
..\..\..\build\trunk\blender-2.5\extern\libopenjpeg\dwt.c(636) : error C2088: '+' : illegal for union
cio.c
Generating Code...
Build log was saved at "file://c:\cmake\install\extern\libopenjpeg\extern_libopenjpeg.dir\Release\BuildLog.htm"
extern_libopenjpeg - 5 error(s), 0 warning(s)
P.S.: Earier I reported that building with mingw / gcc 4.4.1 in windows does not work anymore since approx. svn 29210
Question from Campbell was were do you get mingw with gcc 4.4.1?
Its here - a simple installer from TDM-GCC (tdragon): http://sourceforge.net/projects/tdm-gcc/files/TDM-GCC%20Installer/Previous/1.908.0/tdm-mingw-1.908.0-4.4.1-2.exe/download
I did successful and stable build on Graphicall.org (Zebulon) for quite a while using gcc 4.1.2 and gcc 4.4.1 from TDM-GCC.
There is also a new 4.5 available. But it would be nice to get gcc 4.4.1 going under windows like it works in most recent Linux distributions.
Kind regards,
Ralf Luhrmann
Comment Actions
PPS:
GCC 4.4.1 is also included in Code:Blocks 10.05!
Same there: if you try to build with cmake and Code:Blocks (using Codeblocks mingw setup in cmake) it doesn't build - and here gives a ljpeg linking error (last try approx. 2 weeks ago)
Comment Actions
Fix in svn for the MSVC build error. About GCC building here, you can open a second bug report for that, with the build errors included, it doesn't seem related to this.
