Project: Blender Extensions
Tracker: Py Scripts Upload
Blender: 2.53
Category: 3D View
Python: 3.1
Script name: Mesh: Copy DrawMode
Author(s): wiseman303
Status: Closed
Features:
- Copy settings from the active face to all other selected faces.
- Copy settings from selected faces in another UV texture or vertex color layer to corresponding faces in the active layer.
Setup:
Install as an add-on. Appears under Mesh category.
For additional help see this page: http://wiki.blender.org/index.php/Doc:2.5/Manual/Extensions/Python/Add-Ons
Usage:
Pressing Ctrl-C in the 3D View while in mesh edit mode will bring up the Copy Face Settings Menu.
The following options copy settings from the active face to all other selected faces and may not appear if the mesh does not have a uv texture or vertex color layer.
- Copy Material
Material index.
- Copy Mode
Everything in the Texture Face Panel except Transp.
- Copy Transp
Transp setting from the Texture Face Panel.
- Copy Image
Image used by the face for UV texture.
- Copy UV Coords
The face's UV Coordinates.
- Copy Vertex Colors
The face's vertex colors.
The following options copy settings from selected faces in another UV texture or vertex color layer to the corresponding faces in the active layer and only appear if the mesh has at least two UV texture or vertex color layers.
- Copy Mode from layer
- Copy Transp from layer
- Copy Image from layer
- Copy UV Coords from layer
- Copy Vertex Colors from layer
Finally, buttons have been added to the Texture Face Panel for copying the settings there from the active face to other selected faces in the same layer. They behave the same as the menu options 'Copy Mode' and 'Copy Transp'.
