ASC-CDL Transfer Function in the Color Balance does not match spec
The ASC-CDL transfer function in the Color Balance node does not follow the spec and produces images that do not match the the output of the reference test images.
The spec and sample code is available from:
http://www.asctech.org/archive01/download
Username: asccdluser
Password: asc123456
A patch is in the works to correct this.
I believe this was corrected by Matt Ebb as of SVN 31637.
While Matt has tested this against the ASC provided spec images, it would be good to get confirmation on your end.
Ooh, this was fixed yes. Will close this, if any probs, please reply to this report. cheers
Matt Ebb (broken) changed the task status from Unknown Status to Resolved.Sep 1 2010, 9:27 AM
