On Windows 7 (32 bit) with ATI HD 2600 Pro with Blender 2.53 r30581
Every time I exit Blender, Windows reports:
"blender.exe has stopped working. Windows is checking for a solution to the problem"
The main blender window has closed, but the console window is still open during that time. Here no error or strange info is given.
Can you please try with a recent build? You can find one from my site http://www.letworyinteractive.com/b/
AFAIK this doesn't appear anymore. But please test and report back.
Could you please try with one of my builds too? This is built with the same toolset and machine as the official releases, and I need to know if it may be a different setup from the build you downloaded (probably graphicall - unfortunately not all builders there make good builds :( ).
I tried the 31689, that is yours right?
I tested for 2 hours constantly opening, doing something, closing and so far I haven't seen the "checking for solution" dialog anymore.
So it seems you are right :-)
Great. I'll close this report then. Thanks for reporting!
If in the future you use a Graphicall.org build by another member and you find such crashes, please try also one of mine.
