Compositing nodes + Image editor width scopes for previewing viewer node + Rendering crash instantly
Hello
I tried to use the scopes of the image editor width the composide editor by setting the image editor to viewer node, which works with out problems, but when I try to rerender my scene it crashes instantly after rendering the image.
I attached a Blend for reproducing the problem, it will crash after the second time you hit render, exept there is alredy a render in the buffer then it will crash the first time.
Deactivating scopes(P) in the image editor wont produce any crashes so i'm not sure if this bug belongs to the compositor, node editor or interface Category.
How to recreate the scene:
- Open Blender.
- Split the 3D view in two and and change one into a image editor and the other to compositer nodes.
- Add a viewer node and conect it.
- in the image editor select the viewer node and press the (P) button to show the scopes.
- Render the scene (you might have to rerender the image for crashing in case the render buffer were empty before.)
Testen on Windows Vista 64bit and blender 2.53.1 (R31762) 32bit.
P.S.
This Bug might be similar to bug #22585 "Texture nodes + displacement modifier crash" where two processes run the same time. But i'm only guessing here.
rev31769, ubuntu 9.04 32 bit
Confirmed, here is a backtrace
http://www.pasteall.org/15471/c
Regards
Confirmed here too, assigning to myself.
this is due to a data race:
In colortools.c line 1083 in function scopes_update():
1083 if (ibuf->rect_float) {
1084 if (use_color_management)
1085 linearrgb_to_srgb_v3_v3(rgb, rf);
ibuf->rect_float can be true at line 1083 and then NULL at the line 1085.
However this scope update function is called in space image.c line 840:
static void image_scope_area_draw(const bContext *C, ARegion *ar)
SpaceImage *sima= CTX_wm_space_image(C);
Scene *scene= CTX_data_scene(C);
void *lock;
ImBuf *ibuf= ED_space_image_acquire_buffer(sima, &lock);
if(ibuf) {
scopes_update(&sima->scopes, ibuf, scene->r.color_mgt_flag & R_COLOR_MANAGEMENT );
ED_space_image_release_buffer(sima, lock);
ED_region_panels(C, ar, 1, NULL, -1);
Where the use of the ED_space_image_acquire_buffer() and the lock should prevent this. So it seems the error comes from another part of the code that does not take the lock into account.
I will try to spot where else the data-race occurs with Valgrind and/or try to identify which commit introduce this bug.
Here is the helgrind output regarding this data race:
==2726== Possible data race during write of size 1 at 0x18bf1a4c by thread #1
==2726== at 0xD96C16: image_get_render_result (image.c:1957)
==2726== by 0xD972CF: BKE_image_acquire_ibuf (image.c:2123)
==2726== by 0x8ADA46: ED_space_image_acquire_buffer (space_image.c:113)
==2726== by 0x8AFA5A: image_scope_area_draw (space_image.c:845)
==2726== by 0xB16DE9: ED_region_do_draw (area.c:344)
==2726== by 0x88100F: wm_method_draw_triple (wm_draw.c:594)
==2726== by 0x88170A: wm_draw_update (wm_draw.c:770)
==2726== by 0x87C40C: WM_main (wm.c:345)
==2726== by 0x8689D0: main (creator.c:1154)
==2726== This conflicts with a previous write of size 1 by thread #28
==2726== at 0xD920C7: image_free_buffers (image.c:188)
==2726== by 0xD95614: BKE_image_signal (image.c:1392)
==2726== by 0xE5692F: node_composit_exec_composite (CMP_composite.c:84)
==2726== by 0xDE34B0: exec_composite_node (node.c:2269)
==2726== by 0xECBDF2: tslot_thread_start (threads.c:213)
==2726== by 0x4C29747: mythread_wrapper (hg_intercepts.c:221)
==2726== by 0x5B058B9: start_thread (pthread_create.c:300)
==2726== by 0xA5FB01C: clone (clone.S:112)
==2726== Address 0x18bf1a4c is 476 bytes inside a block of size 560 alloc'd
==2726== at 0x4C23DEC: calloc (vg_replace_malloc.c:467)
==2726== by 0x10E21FA: MEM_callocN (mallocn.c:336)
==2726== by 0xCDF32A: alloc_libblock_notest (library.c:538)
==2726== by 0xCDF525: alloc_libblock (library.c:606)
==2726== by 0xD921DD: image_alloc (image.c:219)
==2726== by 0xD95565: BKE_image_verify_viewer (image.c:1371)
==2726== by 0xB0B844: screen_set_image_output (render_internal.c:260)
==2726== by 0xB0C611: screen_render_invoke (render_internal.c:668)
==2726== by 0x86C44E: wm_operator_invoke (wm_event_system.c:621)
==2726== by 0x86D7E3: wm_handler_operator_call (wm_event_system.c:1166)
==2726== by 0x86E00C: wm_handlers_do (wm_event_system.c:1384)
==2726== by 0x86EE75: wm_event_do_handlers (wm_event_system.c:1709)
Fix in svn, thanks for the report.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Sep 25 2010, 6:35 PM
