Summary: An EXR outputted with Blender itself will crash Blender.
Reproduction: 1) Open compositor add an input node with attached image. 2) Attach input node to Viewer node. Should result in a segfault.
Platform: Linux amd64 (Ubuntu 10.04)
Version: SVN 31704
Backtrace attached.
rev31815, standard compilation flags, ubuntu 10.04 32 bits
Confirmed, it gives another backtrace
http://www.pasteall.org/15520/c
Regards
Hi,
I can't reproduce this from an default file, or any other combination, the only way I got a crash is using the test_dof(1).blend.
The backtrace don't help, because I do different things here, remove the nodes and the image, save with another filename, open again and still have the same problem if I use the blend file and the crash happen in different part of the code.
Can you remember how you create this file ? was with an older version of blender, right ?
BTW I create two exr with blender, one as rgb and another as rgba and both work fine.
Thanks,
- Diego
It was a blend file created with a relatively recent SVN from a friend, so I am unable to recreate it.
It is clearly doing some bad mojo however.
this is a simple NULL check, though I'm not sure if it should just be checked and ignored or investigated further, will leave for now.
