toggle slots in UV/Image Editor - CRASH
1. render the cube in start scene (F12)
2. change light settings, select another image slot, render again,
repeat #2 a couple of times
then toggle between slots via mouse or via short cut "j" -> CRASH
reproducible on my machine, see attachment
Win 7, Nvidia QFX 580, r31829
Failed to reproduce crash here with same revision r31829 running on GNU/Linux with ATI Radeon Xorg open-source drivers.
rev31862, standard compilation flags, ubuntu 10.04 32 bit
it took me some time, but it definitely crashes
will try to provide a backtrace.
regards
I am not succeeding in recovering a backtrace: blender is very unstable with gdb on my computer (not specific to this bug), it freezes very often (I can only move the mouse, nothing else, so only reboot is possible)
Regards
p.s: if anyone has a solution so that I can keep providing some minor help with bug hunting, I'm interested as I've found no explanation on the internet...
updated to r31875, crashes still occur
uploaded dump files
can anyone reproduce this too?
Assigning to myself for further investigation.
Hmm, I'm unable to reproduce this with 2.54.0 r31878 64bit (official beta release), nor with 2.54.0 r31918 64bit.
Setting up debugging for .dmp took a while to realize that you had blender in a location different from where I build to, so had to set up that as well. Anyway, I got nothing useful out of the .dmp, as no symbols for any stack were loaded (and no matching binaries found, are you using 32bit?). Can you still reproduce this with official beta release?
I had the crashes on Win7 32Bit;
unfortunately the crash is not longer reproducible, sorry.
you may close this report.
thanks
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.Sep 15 2010, 9:46 PM
