2.54 31955
Arch Linux
AMD Penome 3 core
2 gigs ram
Open attached Blend
Right click on scale or offset values (inside dropdown)of the texture node and set keyframes. In either case the keyframes are not set.
Also;
Making changes to the texture values (in the texture property window) does not refresh within the node immediately.
Thank you for looking into this.
Comment Actions
Reproduced on Ubuntu 10.04, rev 32024
There is no possibility to animate any Vector Value.
Comment Actions
rev32121
It only works for Compositing nodes.
It doesn't for Texture and Material nodes
