Output that does not append closing slash (/) on directories if file name is empty
Steps to replicate:
1) Go to the Output panel in the Render properties and click the Open File Browser icon at the end of the path field
2) Choose or create a new directory for storing the rendered sequence
3) Leave file name blank
Expected results:
File path should read with a trailing slash (/). When rendering (e.g. an image sequence), the individual files should be numbered and placed within the selected or created directory.
Actual results:
Rendered files are given the selected or created directory as a prefix for each file name. That is, if you created a directory named renders and intended each file in that directory to be named 0001.png, 0002.png, etc., you *actually* get a blank renders directory and each file is named renders0001.png, renders0002.png, etc.
Fix in svn, thanks for the report.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Sep 20 2010, 11:11 PM
